Headlight bearings
Old Jan 13, 2011 | 12:04 PM
V4motorsports's Avatar
V4motorsports
Default Headlight bearings
Anyone know if the plastic bushing in these:
will fit in the old bearings:
or where I can get just the plastic bushings themselves?
Russ
Old Jan 13, 2011 | 01:05 PM
GD70's Avatar
GD70
Just get new ones. 8 bucks each at ZIP.
Old Jan 13, 2011 | 02:17 PM
V4motorsports
I am purchasing the new style from a forum member, but was wondering if the bushing will fit the old type. Not trying to make the car 100% NCRS but would like it to look original.
Russ
Old Jan 13, 2011 | 03:30 PM
GD70's Avatar
GD70
Russ
Paragon, or Doc Rebuild may have them.
Old Jan 13, 2011 | 03:34 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
...Not trying to make the car 100% NCRS but would like it to look original...
The headlight bearings are not judged. They don't show once installed.
Old Jan 13, 2011 | 08:23 PM
grantstigers's Avatar
grantstigers
Russ
Hi Russ
I'm not sure if the plastic bearing will fit in the old style but you can see it has a split so it was pushed in to fit the new style. I am sure the old style is the same too. You can try and take the bushings off the new and put in the old.
BTW. aren't you looking for a set of headlight doors??? I pm'd you and it has the same old style bushings on them. I would use the old ones as one day they will be judged. Only a matter of time.
Thanks, Grant
To Headlight bearings
