Leaking oil...?
Old Jan 14, 2011 | 05:35 PM
Fresshness691's Avatar
Fresshness691
2nd Gear
Default Leaking oil...?
My 1972 corvette is leaking oil when Pushing on the gas... It leaks from between the actual engine and the transmetion....why is this...? And how can I fix the problem...? Thx plz
Old Jan 14, 2011 | 05:41 PM
blckslvr79's Avatar
blckslvr79
Quit pushing on the gas.
Sounds like your rear seal is bad. Oil pressure builds at higher RPM and oil leaks out around the rear crank bearing.
$15 seal. A couple hours on your back.
