rear composite spring.
Old Jan 18, 2011 | 07:16 PM
scyzoryk23's Avatar
scyzoryk23
Default rear composite spring.
I will be purchasing 360lb rear composite spring for my 1981 vette. But witch company should I pick? TWR? VBP?? any other options?
S.
ps. On the end I will want to lower my car 1-2 inch.
Old Jan 19, 2011 | 08:11 AM
muskegonbrake's Avatar
muskegonbrake
Supporting Vendor
Of course I vote for the TRW spring. If you are looking to go lower that will require a longer-than-stock bolt. If you call me to order I am sure I can make up a forum special for you. Let me know if you have any questions on the TRW spring.
Andrew
800-442-0335
Old Jan 19, 2011 | 08:42 AM
alswagg's Avatar
alswagg
I put in a Muskegan TRW spring in 2 seasons ago, Extreamly happy. The rear may be up about 1" higher than front, but that is fine with me. I like being able to run down wavy country roads quick and no bottoming. Muskegan was excellant to work with, very easy to install too. I suggest on buying a set of the High performance shocks also. Al
Old Jan 19, 2011 | 08:57 AM
427SIXPACK's Avatar
427SIXPACK
2025 C3 ('68-'73) of the Year Finalist - Unmodified
2024 C3 of the Year Finalist - Unmodified
Originally Posted by scyzoryk23
I will be purchasing 360lb rear composite spring. But witch company should I pick? TWR? VBP?? any other options?
S.
Curious, why composit ? is your car a custom car ? I once installed one of these, in my other no match vette, it was way too stiff, extreemely bouncey & hated it.......went back to the factory steel / leaf set up.............
Old Jan 19, 2011 | 09:18 AM
scyzoryk23's Avatar
scyzoryk23
I already have 550lb front springs, Bilstien sport shocks (front and back), and HD sway bars (front and back). I need rear spring to match my setup.
I got all that because I want my vette to handle little bit better that what GM had to offer.
S.
Old Jan 19, 2011 | 09:38 AM
Denpo's Avatar
Denpo
S.
I would personally don't go the TWR way because of the height issue.
Old Jan 19, 2011 | 10:37 AM
scyzoryk23's Avatar
scyzoryk23
I am actually buying one from him.
Thanks.
ps. Whats wrong with TWR in relation to height issue? I will use 10" bolts.
Originally Posted by Denpo
I would personally don't go the TWR way because of the height issue, but if you do, the user redvetracr is selling one here, check the for sell part forum. He's not very talkactive but does what he says.
Old Jan 19, 2011 | 10:44 AM
Denpo's Avatar
Denpo
Thanks.
With 10" bolt you should be fine.
Old Jan 19, 2011 | 10:56 AM
Corey_68's Avatar
Corey_68
VDP for me..
Old Jan 19, 2011 | 11:01 AM
mrvette's Avatar
mrvette
S.
Factory steel rides like a WW2 tank, the VBP 360 spring is on the rear of my '72 vert with Bilstein sports for years now, much improved over the KYB shocks....so you set there, just get the VBP spring....and I have 8" bolts, I have a 7/8? front bar and stock rear bar.....my car rides really well...trick is....for lowering you will need to have longer bolts maybe 10" but then you need larger wheel size so when they bounce, the spring straightens out, obviously, so pushes that bolt into the side of the tire....I have stock height and 17" wheels with 8" bolts on my VBP 360 spring.....I dunno if maybe need 18" rims for a 10" bolt.....
I have HEARD that VBP will shorten the spring on each end, allowing use of longer bolts....but you have to inquire over that....
Old Jan 19, 2011 | 11:12 AM
scyzoryk23's Avatar
scyzoryk23
I have 18x9 rims on the back.
S.
Old Jan 19, 2011 | 01:14 PM
WESCH's Avatar
WESCH
Hi
VBP also offer low arc springs that don't put the back up higher.
Rgds. Günther
Old Jan 19, 2011 | 02:41 PM
mauiwilly's Avatar
mauiwilly
I replaced my stock mono spring with the TRW composite and sensatrack shocks in my 81' .......what a difference in the ride and handling Also, reduced the weight in the rear end by about 40 lbs !!
Old Apr 20, 2012 | 05:20 PM
green_79's Avatar
green_79
I am running a TRW rear spring on a 79. I am using 10" bolts. I have 28"(ground to fender well) ride height. The tip of the spring only clears thetire wall by 1/8". What can I do to correct this?
Old Apr 20, 2012 | 05:39 PM
alconk's Avatar
alconk
Just finished installing my 330lb spring from CC. Looks great and rides even better. Also installed Bilstein HD shocks.
Old Apr 20, 2012 | 06:22 PM
Kid Vette's Avatar
Kid Vette
Remove the TRW spring and install a VBP. And you might ask Muskegon Brake to refund your money since they continue to sell springs with known height (over arched) problems.
Old Apr 20, 2012 | 07:28 PM
scyzoryk23's Avatar
scyzoryk23
I have the same problem on my vette. I am thinking about removing the spring and cutting an inch of each side to help with the clearance issue.
OR selling it and get VPB spring.
S.
To rear composite spring.
Old Apr 20, 2012 | 07:51 PM
Paul L's Avatar
Paul L
S.
Cutting and modifying rear springs is not a good idea. It introduces a host of safety issues. Just buy a correct spring.
Why a clearance issue?
Old Apr 20, 2012 | 08:10 PM
SteveG75's Avatar
SteveG75
VBP gets my vote. They will also do custom length and rates for the same cost as their stock rates. Got a 390# spring with 1/2" off each end for my 496 swap.
Old Apr 20, 2012 | 09:18 PM
scyzoryk23's Avatar
scyzoryk23
S.
