Once you remove the two bolts holding the halves together and pull the pad retaining pin, there should not be very much holding them together. The two halves have machined surfaces and are just butted together with a small o-ring at the cross-over port. Have they been painted over? Maybe try giving them a love tap with a rubber mallet.
