Pulling an Engine
Old Jan 20, 2011 | 11:29 AM
lavery48's Avatar
lavery48
Default Pulling an Engine
I need to pull the engine in my 1977 vette. Is it easier to pull eng & trans togeather? I know in alot of regular cars it is but I have never pulled an engine out of a vette.I'm also thinking about going back with a transmission that has more than 3 speeds. What kinda problems am I looking at?
Old Jan 20, 2011 | 12:13 PM
manofsteel1's Avatar
manofsteel1
Can't wait to hear these answers for I have to do the same with my '73.
Old Jan 20, 2011 | 12:16 PM
milo30's Avatar
milo30
Yes it is easier to pull both at the same time. Do it from the side and best to have a helper. I did it by myself and it was a pain to work it out and watch everything at the same time. You will probably need to remove you radiator for the room needed.
Lots of info on here about od transmission swaps. Look at bowtie overdrives website and you'll get some info and prices. Do a search here for lot's of other info on it.
Old Jan 20, 2011 | 12:47 PM
GD70's Avatar
GD70
Also remove the transmission support that's bolted to the frame side rails.
Glenn
Old Jan 20, 2011 | 05:05 PM
FKING1's Avatar
FKING1
I've done it both ways.
Pulled the motor & tranny together only because was replacing it with a 5 speed.
Engine alone no biggy.
Old Jan 20, 2011 | 08:01 PM
onebadmofo's Avatar
onebadmofo
I am about to pull my motor out of my76 and I am wanting to keep the 4 speed trans and bellhousing in the car, will I have any problems with this removal and with the install how will it be mating them back up with the clutch on the motor to the trans?
Sid
Old Jan 21, 2011 | 10:39 AM
lavery48's Avatar
lavery48
SID Which 5 speed did you go with and was it hard to switch?
Old Jan 21, 2011 | 11:28 AM
onebadmofo's Avatar
onebadmofo
No I still have the org. 4 speed, I wish I had a 5 speed.
Old Jan 21, 2011 | 11:33 AM
calif phil's Avatar
calif phil
I pulled the engine out of my 73 and left the 4 speed in the car. It was easy to come out. I am probably going to install it next week and I don't foresee any big deal mating it to the 4 speed.
Old Jan 21, 2011 | 11:46 AM
leadfoot4's Avatar
leadfoot4
Active Streak: 90 Days
My $0.02 worth..
Removing the engine and tranny as a unit CAN be easier, but there are some things you can do ahead of time, that will make it successful. First, get the car up about another 6-8" off the ground (securely). The tranny has to pivot down, as the engine pivots up to clear the radiator support, so you'll need the extra room under the car for that to happen. It will also give you additional work room to un-hook the exhaust, fuel lines, battery cables, shift linkage, motor mounts, ground straps and radiator/heater hoses.
Get a bunch of old blankets, so you can spread them over the body of the car, and duct tape them in place. In fact, you might want one for yourself, to lie on under the car. Most importantly, go slowly and carefully. Most cars are metal, and will tolerate a little bumping and banging, as the drivetrain comes out. 'Vettes are a little more fragile...
To Pulling an Engine
