I have a 1977 Corvette that has set in a garage for about 5 or 6 years. I would like to know What i would need to do to get it mechanically sound, and around how much that would cost. Thanks in advance
My 77 sit for 18 yrs, it needed the carb rebuilt to get it to run, all the interior needed replaced, paint, all bushings, and i'm replacing the top end of the motor for more power, i'm looking at about 15k... And that's not a frame off either...
Its was parked because it belonged to my grandfather before he passed and its has a some paint chipping off the front bumper from running into a ditch and the only reason i know it was parked was because the he didnt want to replace the battery because he hardly ever drove it.
At minimum it will need a new battery, the fuel tank drained and I would change the engine oil, filter and fuel filter in the carburetor before I tried anything else. Check ALL the car's fluid levels, correct as required and add some fresh gasolint to the tank. Remove the power wire from the distributor and crank the engine 15 seconds, then wait a minute and repeat that 4 times to prime the oiling system, and get some fresh fuel in the carb. Plug in the distributor wire and let us know if it runs, and how well... then get back to us BEFORE YOU DRIVE IT ANYWHERE!!!!! Once it runs you'll have to check for leaks, and make certain the brakes work, and do a general safety inspection before you hit the road; so you don't hit anything else.
