What is this?
Old Jan 21, 2011 | 01:57 PM
Snoopysvet's Avatar
Snoopysvet
Default What is this?
What is this and what does it do.
Old Jan 21, 2011 | 03:04 PM
KapsSA's Avatar
KapsSA
Active Streak: 90 Days
EFE valve. (edit...TVS(switch) FOR the EFE system)
When the vehicle operating temp gets up to normal and the thermostat opens the hot coolant hitting it opens(or closes?) (edit...CLOSES) the vacuum line to release and open the heat riser valve between the exhaust manifold and exhaust pipe. (edit...vacuum holds the heat riser closed)
When the heat riser is closed it forces hot exhaust through the intake manifold under the carb for quicker warmups.
Emissions stuff
edit...accuracy!! see post 8
Old Jan 21, 2011 | 03:15 PM
srs244's Avatar
srs244
St. Jude 15 Year Donor
St. Jude Donor '09 thru '26
Originally Posted by KapsSA
EFE valve.
When the vehicle operating temp gets up to normal and the thermostat opens the hot coolant hitting it opens(or closes?) the vacuum line to release and open the heat riser valve between the exhaust manifold and exhaust pipe.
Emissions stuff
Old Jan 21, 2011 | 04:44 PM
ted13b's Avatar
ted13b
I was gonna guess flux capacitor...I'll defer to your superior knowledge.
Old Jan 21, 2011 | 07:49 PM
RunningMan373's Avatar
RunningMan373
EFE valve.
Emissions stuff
This doesn't sound right, aren't the heat risers controlled by a thermal metal spring, at the valve? Not a rubber vac line. I agree, the valve is a temp controlled vacume source, but where does the line go?
Old Jan 21, 2011 | 11:12 PM
KapsSA's Avatar
KapsSA
Pre 75 have the thermal spring, 75-82 use the vacuum system
Old Jan 22, 2011 | 12:42 AM
LT4 F45's Avatar
LT4 F45
EFE valve.
Emissions stuff
Acting as a coolant sensor in the 80's
Old Jan 22, 2011 | 02:55 AM
KapsSA's Avatar
KapsSA
EFE valve.
OK, just to be totally correct.....
That is actually a 'TVS'(thermal vacuum switch) FOR the 'EFE'(early fuel evaporation) system.
And vacuum going through the TVS CLOSES the heat riser. Upon reaching operating temp the vacuum is shut off allowing the riser to open.
Love my shop manual!
To What is this?
