help with axle code
Old Jan 22, 2011 | 01:38 PM
BR_Bo's Avatar
BR_Bo
Default help with axle code
I have a 68 with the 427/400 turbo hydramatic. I should see an AY for the 2.73 ratio and the W for the Warren suffix. As you see the pics below, the date (9-15-67) is easy to see and makes sense as my car was an early 68. WHat do you think of the first part? It looks like the AY is somewhat jammed in with the W. But it also looks like a 7 in front of that. ?? If it were a 1 or 2, that would represent the shift...true? Any ideas?
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
Old Jan 22, 2011 | 02:08 PM
Paul Borowski's Avatar
Paul Borowski
Cruise-In VI Veteran
St. Jude Donor '08-'09-'10-'11-'12
...it looks like that "AY" is stamped on top of a few other characters like you have stated. Many times GM emplyees weren't so neat at doing this, then I've seen other stampings that looked like a machine did it.
....maybe he had too many drinks before his shift that day.
Old Jan 23, 2011 | 11:12 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Originally Posted by Paul Borowski
...it looks like that "AY" is stamped on top of a few other characters...
I think I can see an AY there.
To help with axle code
