Trouble at Harbor Freight !
Old Jan 23, 2011 | 09:45 PM
RedZR's Avatar
RedZR
Default Trouble at Harbor Freight !
Money trouble that is...too many "I wants" and too few dollars
I did but a set of those wheel dollys ($39.99 for a set of two) so I could put my 78 on them and move the car around the garage without starting it.
Those things are really cool- plus they get the car a few more inches off the ground and makes getting under it to clean things much easier. The car moves around the garage pretty easily on them as well!!
I also picked up a low profile jack so I can get under the C6 easier when I change oil.
Things are good in vette land
Old Jan 24, 2011 | 12:56 AM
milo30's Avatar
milo30
I know, Harbor Freight talks you into buying the membership thing and then they bombard you with double or triple ads with deals you just can't pass up. I'm enjoying buying tools and equipment so much, I'm not buying parts! LOL
I know they are crappy tools but for what I need, they will hardly be used and I can get too much stuff too cheap not to. Just wish that I had learned about them sooner.
Old Jan 24, 2011 | 10:35 AM
Roughrider's Avatar
Roughrider
You can find some great deals at Harbor Freight...you just have to sift through a lot of crappy tools to find the good ones. A lot depends on what tool you're looking for and the use you have for it. For something that will get little use buying one of their tools may be OK...but for constant heavy use, I go with something I know can be trusted.
The best thing I bought at Harbor Freight was my utility trailer...$249 delivered. I assembled it and it holds 1100 lbs. It's used regularly and does everything I need.
Old Jan 24, 2011 | 10:44 AM
MrJlr's Avatar
MrJlr
I want a set of roller skates for my Vette too !!!!!
Old Jan 24, 2011 | 11:14 AM
TWINRAY's Avatar
TWINRAY
I've recently been afflicted by the Harbor Freight syndrome. After never buying from them, I've made 3 purchases since last Fall. My wife now tries to throw away their monthly fliers before I see them
Old Jan 24, 2011 | 11:32 AM
randyredleg's Avatar
randyredleg
I bought one of those vibrating multitools (29.95) and it does everything that is advertised in the commercials for similar products that cost ten times as much. I have used it for grout removal,sanding and cutting, and it has been terrific.
Old Jan 24, 2011 | 12:33 PM
buckNeccid's Avatar
buckNeccid
St. Jude Donor '11
For Christmas, I took a Harbor Freight flyer, circled a bunch of stuff I'd like, in various prices, and passed it to my GF. She showed it to everyone who would be getting me gifts I didn't know what I'd get, but this Christmas I didn't get any cologne to add to my collection, or ties to use to clean the dipstick with... it was nice
Roughrider.... all in all, how is that trailer? I've been thinking about getting one and building a teardrop on it, just for the Vette.
Old Jan 24, 2011 | 05:11 PM
Roughrider's Avatar
Roughrider
It does everything I need...I use it for carrying occasional furniture, mulch, even a friend's motorcycle when it broke down on him in the middle of the night. Friends have also borrowed it to carry air compressors and lawn equipment over hundreds of miles.
The only issues were the paint fading from red to orange (the trailer sits out in the weather) and having to replace the wheel bearings after enough time, but it uses standard 1" bearings which are very inexpensive.
Harbor Freight sells several sizes and weight carrying ability...mine has a 4'x8' bed and has the 12" tires. The same trailer with 8" tires is rated to carry less weight. I added a steel reinforcing bar down the center to stiffen it more as it has a fairly light gauge frame.
I believe the retail has gone up about $50 since I bought mine about ten years ago. When I ordered it originally, it came by freight at no charge which was a big plus. Now I have a Harbor Freight store about thirty minutes from me which is convenient.
For the money it's hard to go wrong.
Old Jan 24, 2011 | 09:59 PM
Mark G's Avatar
Mark G
I second that! I wish I would have had it to cut my vette's fender off back when I replaced it. I bought a house that had some frozen pipes and it is THE tool for making plunge cuts into drywall. What I like is the blade is only about 1mm thick.
Mark G
Old Jan 24, 2011 | 10:17 PM
Aruba1's Avatar
Aruba1
bought two sets of 1000lb dollies last week for $30 each (inside track). When I checking their rating on HF it turned out that the 1000lb is easier to maneuver than the 1500 lb ones. I compared them side by side at the store and indeed the 1000 lb has bigger wheels. They worked great with the 68 vette.
Old Jan 24, 2011 | 11:12 PM
HerFirstVette's Avatar
HerFirstVette
I bought the 1000 lb set for my C4 and they work great. But I swear I was walking thru Menard's a week later and saw the exact same dollies (or very, very close) for less.
My favorite disposable HF tool is the electric die grinder I bought with the extended reach (long shaft). I put 2" dia abrasive cut-off wheels on it and with the small wheels I was able to reach into the access areas to cut the body mount bolts. It's been handy for all kinds of tight places.
As for the car dollies...it was like adding square footage to the shop because I pushed the C4 sideways into the corner.
crf311's Avatar
crf311
China loves you guys.
Old Jan 25, 2011 | 05:14 AM
milo30's Avatar
milo30
If it weren't for China then I couldn't afford to buy the American parts to rebuild my car and enjoy this hobby.
Old Jan 25, 2011 | 08:04 AM
ghoastrider1's Avatar
ghoastrider1
gonna have to go check out the local one. You guys have perked my intrest.
Old Jan 25, 2011 | 10:21 AM
buckNeccid's Avatar
buckNeccid
St. Jude Donor '11
WARNING WARNING WARNING
Entering a Harbor Freight Store for the first time WILL steal several hours of your life due to mesmerization, and you will leave with a large purchase you didn't plan to make!
Old Jan 25, 2011 | 10:40 AM
Jeff_Keryk's Avatar
Jeff_Keryk
I hate cheap tools, but they sure are handy when you need 'em! They are opening a new HF store in San Jose near me. I will probably be in big trouble... "He who dies with the most tools wins."
Old Jan 25, 2011 | 12:59 PM
toddalin's Avatar
toddalin
This is easy to "cure."
Simply buy a few tools there that you absolutely need to do a specific job.
When some break down on you (always at the most inoppertune time), you'll be on your way to the cure.
When others don't perform as they should, you'll take the next step.
Then, when you find that the remaining tools have totally screwed up your work, you'll be cured...,
temporarily...
Case in Point from my actual experience:
Buy a belt for your stationary belt sander from Lowes/Home Depot/Osh and run a piece of wood over it. It goes "SHSSSSSSSSS..."
Buy that belt at Harbor Freight for half the price and run a piece of wood over it and it goes "****-****-****..."
To Trouble at Harbor Freight !
Old Jan 25, 2011 | 07:56 PM
Aruba1's Avatar
Aruba1
Exactly!
Old Jan 25, 2011 | 11:37 PM
HOOAH's Avatar
HOOAH
1969/1971/2021 Coupes
St. Jude Donor '09-'10-'11-'12-'13-'14-'15
You will never want to leave. Like others have said, the tools are not the greatest but you can go in there and buy stuff after looking at the real thing and not just a picture in a mag. I now have a machine shop of Harbor Freight tools.
Oh yea, those vette roller skates are saaaweeeet!!!! Sometimes I go out in the garage and just push the Vette around, because I can!
Latest purchase was an dust exhaust/filter system for the cabinet sandblaster, that sits next to the cherry picker, that sits next to the parts washer, that is right next to the bench grinder that just happens to be along side of the drill press etc etc etc.......... Plus I have a boatload of those little free flashlights they give when you buy anything.
Old Jan 26, 2011 | 12:38 AM
mrit's Avatar
mrit
The 2 ton Snap-on engine hoist is also made in China. Everything is...
Their composite ratchets are actually pretty darn nice, Haven't broke it yet. My S&K and Stanley ratchets did break. You gotta read the reviews on their website before making purchases, they do have alot of crap.
