1969 Horn
Old Jan 24, 2011 | 07:44 AM
jack kennedy's Avatar
jack kennedy
Default 1969 Horn
Can anyone tell me how to install the spring, insulator, and small metal post in the hole in the steering column for the horn contact? Thanks.
Old Jan 24, 2011 | 08:47 AM
Jim Shea's Avatar
Jim Shea
The horn plunger parts are pretty generic so this picture is correct for the way the parts go together.
First insert the spring, then insert what is called the eyelet with the upset end first. The last part should be the plastic bushing or insulator.
Sometimes if you have a kit with replacement parts the eyelet may to too long and will need to be cutoff to a shorter length. (Cut it to the length of the original part. Or if you don't have the original, you will need to trial fit the parts with the upper horn contact in place.)
Jim
Old Jan 24, 2011 | 09:18 AM
jack kennedy
Default C# horn
Jim
Thanks. Do the little ears on the insulator have a purpose as to the spring or eyelet?
Old Jan 24, 2011 | 10:22 AM
Surfer69's Avatar
Surfer69
I had a problem with the aftermarket parts not made correctly and would touch and short on the steering wheel shaft nut if you don't protect/insulate around it.
To 1969 Horn
