Broken Tach Needle
Old Jan 26, 2011 | 08:09 AM
donnie1956's Avatar
donnie1956
Default Broken Tach Needle
Where can I purchase a replacement tach needle? I broke the old one trying to reset tach to zero, and have the base. Can a new needle be glued to the base?
Old Jan 26, 2011 | 09:54 AM
BKarol's Avatar
BKarol
It appears most vendors carry them:
ie. http://www.zip-corvette.com/ProductD...GR-SR&CTitle=&
http://willcoxcorvette.com/advanced_...edle&x=69&y=13
You must need to buy something else so throw it in with the rest. If they send it in an envelope, you know the P.O. will break it.
Doesnt need to be glued.
Old Jan 26, 2011 | 11:17 AM
donnie1956's Avatar
donnie1956
Ordered a new one from Full Throttle Corvette. $12 also ordered the speedo to match. Old parts are brittle and clumsy fat fingers don't help.
Old Jan 26, 2011 | 11:49 AM
toolman1981's Avatar
toolman1981
By the way, the tach does not "rest" in the zero position on later c-3s.
Old Jan 26, 2011 | 01:21 PM
donnie1956's Avatar
donnie1956
Right, the tach bounces and stops wherever, but returns to zero with power on. I was attempting to set it to zero with the power on and dropped it and ended up breaking the needle due to clumsiness.
Old Jan 26, 2011 | 01:40 PM
toolman1981
Been there, done that! LOL
Old Jan 26, 2011 | 02:47 PM
Willcox Corvette's Avatar
0Willcox Corvette
Former Vendor
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
Donnie,
You'll need to do a zero set on the needle when you install it.. we have a video on U tube and a page in the help repair section on how to do this.
Willcox
Old Jan 26, 2011 | 03:13 PM
KapsSA's Avatar
KapsSA
Active Streak: 90 Days
I too broke the tach needle on my 78SA.
The replacement needle, actually a speedo needle, didn't work as received. The hole in the hub was too big for the tach stud.
I simply very carefully sliced the plastic 'weld' off from behind and transferred the needle itself to my original tach needle hub.
Took a soldering gun and carefully melted the material in the hub hole.
You'll see what I mean when you get there.
edit...just looked at the Zip link.
They mention the hub situation....
Old Jan 26, 2011 | 04:11 PM
donnie1956's Avatar
donnie1956
Can't wait. Maybe try not to drink as much coffee before I attempt the new one.
Old Jan 27, 2011 | 09:54 AM
0Willcox Corvette
Former Vendor
Kaps, That is a very good point so this morning I added a note to the one on our site.
To Broken Tach Needle
