Alternator going bad.
Old Feb 1, 2011 | 12:32 PM
daanbc's Avatar
daanbc
St. Jude Donor '12
Default Alternator going bad.
My alternator is showing signs of it going. When at idle she reads 13 V. But the generator light comes on and off. When I step on the accelerator she immediatly goes right up to 18 V. So I know it's time. Is there a preference to what kind I should get? Thinking that maybe I want one with a chrome case to dress up the motor a bit. What do you think? (77-L48 Auto)
Old Feb 1, 2011 | 12:43 PM
MrJlr's Avatar
MrJlr
I just got one from Summit...I got a 140amp because I added duel electric fans...
$168
Old Feb 1, 2011 | 01:11 PM
Nowhere Man's Avatar
Nowhere Man
2015 C2 of Year Finalist
you can also have your original one rebuilt
Old Feb 1, 2011 | 09:57 PM
Ironcross's Avatar
Ironcross
reading 18 volts will blow out electrical parts that only need 12 volts like bulbs ect...that are probably brighter than hell...you need that corrected and its a good chance its the regulator....and most Corvettes use a alternator with a built in regulator depending on the year
Old Feb 1, 2011 | 10:36 PM
daanbc's Avatar
daanbc
St. Jude Donor '12
Never thought about that. Blowing the electrical with 18v. Thanks for the heads up.
Old Feb 2, 2011 | 12:24 AM
daanbc's Avatar
daanbc
St. Jude Donor '12
My alt. has a plug with two wire on the top side. and one wire that bolts to the back. Does this make it a 3-wire hook up (is the plug called a pigtail?) Or do I have what they call a One wire alternator? Looking at a lester 7127-105c. Not sure if it will fit. I believe it will.
Old Feb 2, 2011 | 01:43 AM
KapsSA's Avatar
KapsSA
Active Streak: 90 Days
Or rebuild it yourself. They're not really a big mystery.
If it's original to the Vette and dated/numbered correct, at least don't trade it in.
Rebuilding is simply replacing the stuff in the back of the alternator and the bearings. And clean the case up, I use "Barkeepers Friend" and water and some stiff brushes.
If you decide to go this route I or many others here can talk you through it.
Old Feb 2, 2011 | 06:45 AM
noonie's Avatar
noonie
The regulator is bad. Max on yours should be no more than 14.7v and 55˜amps.
You have a standard regulator in yours, not a 1 wire.
If yours is the original, then just get a cheapie replacement and keep yours to rebuild at your leisure, parts are cheap, only a few minutes to change out.
Here's a 63 amp for yours that you can get locally.
http://shop.advanceautoparts.com/web...S_539074357___
Old Feb 2, 2011 | 08:59 AM
daanbc's Avatar
daanbc
St. Jude Donor '12
Im gonna check it out today.(see if it is an original) That is why I was asking about this Alt. lester (7127-105c.) It is cheap and will would be great to put in its place while I do a rebuild and clean the original. Thanks for all the help
Old Feb 2, 2011 | 10:19 AM
daanbc's Avatar
daanbc
St. Jude Donor '12
Is there a certain place to look on the Alt. for a # to find out if its an original , or repo? I won't be pulling it out till late this afternoon. Waiting for my 14 year old son to come home from school. Going to have him take it out. (teaching him the ropes)
Old Feb 2, 2011 | 12:54 PM
KapsSA's Avatar
KapsSA
This is a 79 alternator....
The 79D12 is the date, April 12, 79. Your date should be up to a few months to a couple weeks before your Vette's production date. It might not be '77', just '7'.
Part no above it.
I believe possible part nos. for 77 are....
1102474
1102484
1102908
1102909
Old Feb 2, 2011 | 01:01 PM
Ironcross's Avatar
Ironcross
$168
The Summit alternator has a front wheel drive fan on it and cannot cool correctly with that plastic fan...the solution is to remove the plastic fan and put the original metal fan on the remanufactured unit....
I would not be looking to expect the original alternator to still be on a 35 or so year old car....But the numbers are stamped into the rear case
Old Feb 2, 2011 | 01:29 PM
daanbc's Avatar
daanbc
St. Jude Donor '12
I believe it may be the original! It has a # 1130923
123 12W 7 s?
Old Feb 2, 2011 | 01:36 PM
KapsSA's Avatar
KapsSA
Not even close.
Old Feb 2, 2011 | 01:55 PM
daanbc's Avatar
daanbc
St. Jude Donor '12
I just put a light on it: 1100928 55A
K23 12YNE.
To Alternator going bad.
