Brake Hose Question
Old Feb 8, 2011 | 05:00 AM
briaineo's Avatar
briaineo
Default Brake Hose Question
Do the fittings on the front rubber brake hoses fit the master cylinder?
Waiting for the bleed kit to arrive and was wondering if the rubber hoses might do the job!
Old Feb 8, 2011 | 05:47 AM
69small block's Avatar
69small block
Default hose
I would be concerned about trash getting into your new fluid or moisture but never tried the hose there
Old Feb 8, 2011 | 06:35 AM
briaineo's Avatar
briaineo
The hoses are new never even had fluid through them!
I would imagine that it might work if the're the same size.
Old Feb 8, 2011 | 06:36 AM
corvetteload's Avatar
corvetteload
If you have a set of new ones laying there, only one way to find out!!! My guess is yes
Old Feb 8, 2011 | 07:18 AM
noonie's Avatar
noonie
The hoses won't fit the master
The master sizes are
Front 1/2-20
Rear 9/16-18
Old Feb 8, 2011 | 07:29 AM
briaineo's Avatar
briaineo
Front 1/2-20
Rear 9/16-18
what size are the brake hoses?
could have sworn that I used the same size wrench to loosen both nuts on the master cylinder
Old Feb 8, 2011 | 08:55 AM
noonie's Avatar
noonie
I don't remember, but hose threads are a lot smaller. They were purposely made different so people couldn't do silly things.
The master fittings are uncommon, same size nut, different threads and different hole size, one is for 3/16 and the other for 1/4" tubing.
Old Feb 8, 2011 | 08:56 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Originally Posted by briaineo
...Waiting for the bleed kit to arrive...
Wait for the kit.
Old Feb 8, 2011 | 09:57 AM
joewill's Avatar
joewill
while I am all for using the corvette forum to answer questions and get expertise, but why string along a thread where you will get several different answers when it is much easier to walk out in the garage and just find out in less than a minute?
Old Feb 8, 2011 | 10:28 AM
briaineo's Avatar
briaineo
unfortunately for me my car is 120 miles away, if it wasnt I wouldnt have asked the question
To Brake Hose Question
