Carburetor For 69 BB
Old Feb 15, 2011 | 08:37 PM
axelz's Avatar
axelz
Default Carburetor For 69 BB
What Rochester Quadrajet came with the 69, 427 390 hp, auto? Serial number and size and where I could find one.
Old Feb 15, 2011 | 09:15 PM
speedreed8's Avatar
speedreed8
the chart i have from Lars, shows 2 carbs. dont know what hp engines they were on,
and it doesnt say what cfm they are.
carb no.
7029200 CHEV 69 CAMARO, VETTE 396/427 AUTO mainjet #71 main rod #49
7029204 CHEV 69 CAMARO, VETTE 396/427 AUTO mainjet #71 main rod #47
http://cgi.ebay.com/ebaymotors/70292...Q5fAccessories
Old Feb 15, 2011 | 09:21 PM
PeteZO6's Avatar
PeteZO6
I'm not sure if this is the answer you are looking for. The Black Book lists Q-jet #7029204 for a 427ci, 390hp, at
Pete
Old Feb 16, 2011 | 07:18 PM
roy69's Avatar
roy69
Pete
That's what came up on a couple of carb look up tools, like the one at Carbs Unlimited.
Old Feb 16, 2011 | 08:19 PM
Faster Rat's Avatar
Faster Rat
2024 C3 of the Year Finalist - Unmodified
I thought the '69 L36 carbs were rated 790 cfm.
If you are looking for the correct #7029204 carb then you will be looking at a rebuilt. I found one for my L36 manual car (#7029215) that had an acceptable date code...the only problem was they wanted $1395 plus S & H for it. Your search results may vary. Just remember you are buying a rebuilt carb, so it will only be as good as the core they used and what they did to it.
Instead I found a brand new GM replacement carb (#17054696) still in the shrink wrap and box from what I believe was 1986. Cost $722 plus S & H. It was a late 70's issued SERVICE carburetor for 1971 big block applications, including the 1971 Corvette LS5. It is identical in both configuration and appearance to the correct carb for my car, but supposedly has some "emissions" built into it. I believe the correct carb should have 71 primary jets, 45 primary rods and AX secondary rods. I still need to find out what my replacement carb has and play around with it. I've already replaced the accelerator pump because of the age. Nothing performs like a brand new carb with no wear and tear. Nothing.
Old Feb 17, 2011 | 07:34 PM
axelz's Avatar
axelz
Thank you all for the information. Know I know what to look for.
Old Feb 18, 2011 | 04:51 PM
RagTop69's Avatar
RagTop69
My "1968-1969 Corvette Technical Information and Judging Manual" indicates on page 43 that the correct carbs for 427/390hp cars are Quadrajets #7029204 for an automatic and #7029215 for a manual. It tells me that the part number on a Q-Jet will have the P/N stamped on the vertical boss on the driver's side of the main body. It also notes that some carbs have the full seven digit P/N stamped there and others have just the last five digits. In additon, just to make things easier, there may also be several alphanumeric characters stamped on the boss by the part numbers to indicate manufacturing plant. Date codes for the Q-Jets are stamped on the drivers side edge of the base plate near the rear. Rochester built Q-Jets will have a four numeral date code with the first three indicating the day of the year (001-365) and the last digit the year. A carb built on January 5, 1969 would show 0059. Carter manufactured Q-Jets will have a different date code in an MY configuration where M= month and Y= last digit of the year. The Carter month codes were A-M for January to December, so our example carb would be coded A9.
Old Feb 18, 2011 | 07:21 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Originally Posted by axelz
...now I know what to look for...
Finding one is one thing; paying for the one you find is another.
Originals are 40 years old now, and expensive.
Good luck with the hunt.
To Carburetor For 69 BB
