Front coils
Old Feb 19, 2011 | 02:35 PM
ratflinger's Avatar
ratflinger
NCM Grand Opening Veteran
St. Jude Donor '11, '17
Default Front coils
Ok, after all this time I'm finally putting the car back together. Put the new coils in & attached the spindles. Left side - on whack with a rubber mallet seated the spring in it's pocket, but on the right - not so lucky. Any good ideas to seat this spring? (removing the spindle again is NOT a good idea)
Old Feb 20, 2011 | 07:49 PM
dgood's Avatar
dgood
I had the same problem. I put a jack under my lower arm, disconnected the spindle (this is the only way I knew how to do it) and slowly lowered the jack. Once all the tension was gone, hit it with a BFH and popped right in. The BFH may work for you with out disconnecting the spindle. Try it.
Dan
