What is this part?
Old Feb 21, 2011 | 08:55 AM
Jeff1981's Avatar
Jeff1981
2nd Gear
Default What is this part?
Hi all. Can someone tell me what this part is? My uncle owned several Corvettes in his life and it was among some stuff I received after he passed away a few years ago. I'm assuming it is a Corvette piece and I'm in the correct year range for it. It doesn't have any markings on it other than Delco.
Thanks!
Old Feb 21, 2011 | 09:15 AM
gbvette62's Avatar
gbvette62
It's not a Corvette item, or at lease not an OEM one.
I know I've seen those controls before. It may be the underdash control for a Delco air shock system, with an on board compressor.
Old Feb 21, 2011 | 09:20 AM
HOOAH's Avatar
HOOAH
1969/1971/2021 Coupes
St. Jude Donor '09-'10-'11-'12-'13-'14-'15
Hey Jeff, I believe this is one of those C3 airspeed indicators. Anything below 30 would cause the vehicle to fall from the sky. The green range was the optimal flight range whereas the yellow was starting to get into the area where the structural integrity of the Vette had to really be watched (while in flight). On the ground the gauge was not needed because there were no speed limitations.
Actually, I have no clue what it is but made for an interesting story, right?
Take care,
Terry
Old Feb 21, 2011 | 10:01 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
For some model years, air shocks were a dealer option. Looks like you inherited one of the air shock controllers.
Old Feb 21, 2011 | 10:08 AM
RonR80's Avatar
RonR80
St. Jude Donor '09
Muffler bearing air flow indicator.
Old Feb 21, 2011 | 12:01 PM
GREGG-73's Avatar
GREGG-73
Stay in tune....
Old Feb 21, 2011 | 12:28 PM
Mike Ward's Avatar
Mike Ward
Sure it's not a headlight fluid indicator?
Old Feb 21, 2011 | 01:28 PM
ozzyrulesme's Avatar
ozzyrulesme
It' so you could adjust the horn tone. On the 83's...
Old Feb 21, 2011 | 03:26 PM
RonR80's Avatar
RonR80
St. Jude Donor '09
OH that's good
Old Feb 21, 2011 | 04:02 PM
john 72-04's Avatar
john 72-04
You've got the main part but you still need a spool of flight line and two sky hooks to make it complete. After that you're on your way. Actually I have no idea what it is. I think Easy Mike might have it. Good luck with your search.
To What is this part?
