Exhausted
Hi all new member here just bought a 79 c3 bone stock 350 auto.
Was wondering if anybody new the size of the exhast manifolds on an L48 79 350 2 inch 2 1/2 ?
i want to buy a true duel exhaust system and the one i found id a 2 inch ?
Uploaded with ImageShack.us
The "cat" had be removed from my '79 and been replaced with a "cheater" pipe. When I found the rear "Y" pipe rusted out, I put a set of '74 style 2" duals on it that I got from Zip Products. I used the Magnaflow mufflers that were already on the car but had to get 2" to 2 1/2" pipe adapters in order to use them. Had I used a 2 1/2" dual set, I wouldn't have had needed the adapters. You will also need front exhaust hangers and clamps. Good Luck
You can try any of the supporting vendors, 2" and 2-1/2" are common dual replacemsnts. Check your local laws before doing anything. Not sure were you live.
http://www.corvettecentralexhaust.co...mance_dual.php
[QUOTE=mikep3;1576997861]You can try any of the supporting vendors, 2" and 2-1/2" are common dual replacemsnts. Check your local laws before doing anything. Not sure were you live.
http://www.corvettecentralexhaust.co...mance_dual.php[/.
I bought a true dual exhaust from cc it came out great
[QUOTE=c4nutcase;1576997915]
Yes I also removed the cat top and the shield I,ll post a bid later today
how are those shorty headers compared to long tube headers on a mostly stock engine?
i will go with thesehttp://www.vetteheaders.com/servlet/StoreFrontand i just found this one http://forums.corvetteforum.com/c3-t...e-special.html
