'79 Speedo Bounce
Old Feb 24, 2011 | 03:48 PM
79vetter's Avatar
79vetter
Default '79 Speedo Bounce
My speedo is a little inconsistent. Little wobbly til 20 mph. Nice and steady @ 30mph. And then it fluctuates back and forth about 5mph when I get over 50 mph. I replaced the speedo cable about 5 years ago - only 700 miles since - non cruise control car. These results are when I pulled the cable from the transmission and used a drill.
Does this sounds more like a speedo rebuild needed or a speedo cable/lube issue?
thanks
Old Feb 24, 2011 | 04:22 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Lube first.
Old Feb 25, 2011 | 01:33 AM
mapman's Avatar
mapman
As already stated, lube first.
Just curious: if the car is an automatic, do you have an ATF leak where the speedometer cable enters the transmission?
If the transmission o-ring seal is bad, then ATF might be working its way up the speedometer cable.
Old Feb 25, 2011 | 10:02 AM
79vetter's Avatar
79vetter
It a 4-spd car....Are people using the speedo lube from Willcox these days to safely lube the cable?
Old Feb 25, 2011 | 10:46 AM
builder's Avatar
builder
I took a "little" wd-40 and sprayed it into the back of the speedo where the cable goes into. Drove it for a couple of hundred miles and it straightened it out. Be careful if you try this so you don't get to much in it and lube the face of the speedo.
Old Feb 25, 2011 | 10:55 AM
corvetteload's Avatar
corvetteload
Had that problem with my first 69, jumpy needle, it seized and twisted the end off the cable. Had a new cable made with metal end, it broke the speedometer.
Old Feb 26, 2011 | 04:24 PM
79vetter's Avatar
79vetter
I bought a new cable - lubed it with white lithium grease - took the speedo out of the car so there were no cable bends - connected my drill - SAME results
I'm now looking for a good resource to rebuild a '79 speedo....
Old Feb 26, 2011 | 05:01 PM
manofsteel1's Avatar
manofsteel1
Funny....instead of my speed bouncing......my tach does the same thing and can not get it to stop bouncing......any thoughts on that? Thanks
To '79 Speedo Bounce
