From: Arlington Va Current ride 04 vert, previous vettes: 69 vert, 77 resto mod
the ring gear teeth just have to line up with the starter teeth....most have 168 teeth. you can get them from summit...from memory i think the two choices are 153 or 168. and i think my mini starter would drive etiher....
are you installing this or is the machine shop? maybe let the machine shop source it and mill the fly wheel while its there, that way its a guaranteed correct fit
Some of my books show a 153 tooth gear for a 70 350/350. The one I took off is a 168 tooth, but it appears to have been replaced at one time long ago. I did not see them from Summit, and a lot of the Corvette parts houses do not list how many teeth. I will be installing it myself.
Are you saying that you have the flywheel off the car, and it has 168 teeth? What diameter is the flywheel? And what diameter is the clutch disk? The 153 tooth flywheel takes a clutch disk that is 10.4" in diameter. The 168 tooth flywheel takes a clutch disk that is 11" in diameter.
I'm also not sure why you want to just replace the ring gear. Why not just get a new flywheel? Once you get the new ring on the old flywheel and get it resurfaced, you're probably not money ahead.
If your current 168 toother works it is correct for your application... why would you question what is currently working in the car? Just like refrigerators, microwaves and the like; there are probably not too many actual ring gear manufacturers out there... most are likely sourced from the same factory so buy the best deal. Ring gears are easy to replace yourself... simply cut the old one off with a die grinder, heat the replacement evenly with a torch until it just starts to turn a "straw" color and drop it in place. Might need a bit of push from a brass hammer to seat fully, but it really is that simple a task.
Okay, the clutch disk is 11". The diameter where the ring gear mounts is roughly 13 1/4" The old ring gear was 168 teeth. It was in bad condition, with hardly any teeth left in one area. The starter turned out to be from a 66 Olds. Since this engine and car has been in the hands of Bubba, I was being cautious as to what might have been replaced and not correct. From what I have learned so far, it appears that the 168 tooth gear is what I need.
There is nothng wrong with the flywheel and it worked well with the clutch, very smooth. Why spend more money on a new flywheel when I can replace the ring gear myself for so much less. I have already cut the old ring gear off the flywheel and as mentioned above by Markids77, it should be a snap to put the new one on.
Reason: added text
