After all the work to finesse it in, getting it tweaked to how it should look, and grumbling about the fit and finish of it.....it turned out great. The interior looks very nice.
This thread is over four years old and since this time, the pad has been re-tooled. We did a pictorial of an installation we did in our shop and added some tips to help install the pad on our Facebook page. I don’t know about the grain comparison, but the material and weight of the pad seemed to be fine. Installation of this pad is a beast of a job for anyone!
Willcox
I'm sure a lot has changed with these parts over the last few years but I got a replacement pad through Willcox from Al Knoch not long ago and my impressions are somewhat different. I remember this post years ago because of the packaging. Al's arrived in a long, skinny box with the pad wrapped in cheesecloth. No padding at all. Still got here in one piece though. It is very noticeably lighter than the original but I thought the grain and vinyl were an excellent match. There were a couple of minor defects such as a staple sticking out and a corner that wasn't neatly finished that I'll have to fix before installing but generally, my impression is good. As the OP mentioned, the fit and finish on these cars wasn't good when new so I'm never sure if I'm fixing the shortcoming of a part or the original design.
I plan to install it tomorrow morning so I'll add final impressions then.
Don't drill holes... Mark them and then burn them into the pad with a heated small awe. Check the facebook installation for other tips too.
Installing the center dash bezel.. Get the sides where they need to be, test fit the center dash bezel... Mark the holes then burn (see below) in the pilot... Make sure the side screws are short if not you'll poke a hole through the pad. We have a "marking core" we use to mark the holes...
We then use the heated awe to burn pilot holes in the pad and then we install the screw. Same goes for the wiper switch. make sure you have it in the right place, make your pilot and then screw it down.
It used to take me 8 hours start to finish to do one of these years ago, I'm sure my guys can replicate that but I'm sure there is no way I'd do it that fast today and don't try too... Take your time.
