68 protecto plate question
Old Mar 5, 2011 | 04:12 PM
TOM65 L76 96 LT1's Avatar
TOM65 L76 96 LT1
Default 68 protecto plate question
On the left hand side directly under the engine code is CK683335, anybody know what this is?? the only thing I can think of is the key code, thanks.
Old Mar 5, 2011 | 04:48 PM
bkvette3's Avatar
bkvette3
Someone correct me if I am wrong - transmission source and date code
Old Mar 5, 2011 | 04:52 PM
PRNDL's Avatar
PRNDL
Supposed to be trans. Those numbers/letters don't look exactly right. Do you have a smallblock automatic?
(Having trouble reading backwards?)
Old Mar 5, 2011 | 04:58 PM
TOM65 L76 96 LT1
Yes, base 300hp engine with turbo 400 trans, I think the trans code is AV0502W which is on the right hand side directly under the Vin number.
Old Mar 5, 2011 | 05:03 PM
bkvette3's Avatar
bkvette3
I think that number (AV0502W) is the rear axle number
AV - posi 3.08 ratio
05 - May
02 - 2nd day of month
W - Warren plant
Old Mar 5, 2011 | 05:07 PM
TOM65 L76 96 LT1
05 - May
W - Warren plant
OPS, you are correct, rear axel not trans.
Old Mar 6, 2011 | 12:31 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Tranny code.
Old Mar 7, 2011 | 01:48 PM
TOM65 L76 96 LT1
Thanks guys, have the answers to my questions, one final remark regarding the codes on my protecto plate, rear axel code is AV0502W, if I looked at the code list correctly the code for my s/b engine with the 3.08 ratio should be AL, AV is the code for the b/b engine with the 3.08 ratio, do you think this is an example of a car going down the assembly line and a part that was to go on the car was not available so the workers installed the next best thing?? we all know that the assembly line was not going to stop, guess I will just have to check when the car is delivered around the middle of April, besides was there a difference in the 3.08 ratio between the s/b and b/b engine??
Old Mar 7, 2011 | 04:11 PM
Easy Mike's Avatar
Easy Mike
...axel code is AV0502W, if I looked at the code list correctly the code for my s/b engine with the 3.08 ratio should be AL, AV is the code for the b/b engine with the 3.08 ratio, do you think this is an example of a car going down the assembly line and a part that was to go on the car was not available so the workers installed the next best thing??...
No. Much more likely to be a typo error by the fellow filling out the factory portion of the POP.
Old Mar 7, 2011 | 08:10 PM
TOM65 L76 96 LT1
Mike, good thought, when it comes off the truck this code will be one of the first things I check and post here on the Forum.
To 68 protecto plate question
