Very cool
Old Mar 8, 2011 | 11:30 AM
Snoopysvet's Avatar
Snoopysvet
Default Very cool
All you guys probably know this however this was new for me. While adjusting the timing I turned the distributor too far where the car would not start.
With the T-Top off you can crank the engine with one hand, lean over the windshield and manually turn the distributor with the other hand.
A one man operation, could not do that with an old Camero!
Old Mar 8, 2011 | 12:03 PM
Kevin_73's Avatar
Kevin_73
Cruise-In X Veteran
St. Jude Donor '09-'11
Just be careful grabbing the distributor by the cap. A bad/improperly seated boot or a cracked cap and you will get a ****load of voltage shooting up your arm that will cause your fingers to clamp down even tighter, and you won't be able to let go until the convulsions in your body get large enough to knock you off of it.
Or so I have heard.
Old Mar 8, 2011 | 12:28 PM
Snoopysvet's Avatar
Snoopysvet
Ha - The results could be shocking!!!
Old Mar 8, 2011 | 12:30 PM
Kevin_73's Avatar
Kevin_73
Cruise-In X Veteran
Always grab the distributor by the base when the engine is running.
Old Mar 8, 2011 | 01:55 PM
Birdman's Avatar
Birdman
My ignition is on the dash.
Wait, I actually like that more...
Old Mar 8, 2011 | 04:35 PM
Snoopysvet's Avatar
Snoopysvet
I don't get it?
Old Mar 8, 2011 | 09:32 PM
kdf1986's Avatar
kdf1986
1968 Vettes had the key ignition on the dash. In 1969 they moved the key to the steering wheel stalk.
I think that is one of the many unique characteristics of the 1968 he was referring to.
kdf
Old Mar 8, 2011 | 09:44 PM
scott2173's Avatar
scott2173
Or so I have heard.
kinda sounds like you might have some experence with this shocking issue
Old Mar 8, 2011 | 09:52 PM
Kevin_73's Avatar
Kevin_73
Cruise-In X Veteran
Very recent too.
Old Mar 8, 2011 | 11:40 PM
Birdman's Avatar
Birdman
kdf
Correct, but it also had to do with the OP's technique. I wouldn't be able to pull it off because I would have to reach further...on top of being a short guy, lol.
Old Mar 9, 2011 | 10:11 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
I use a static timing light to set the distributor for intial start. No bending over the windshield.
To Very cool
