steering column part
Old Mar 9, 2011 | 07:19 PM
baxsom's Avatar
baxsom
Default steering column part
I have seen this before on another thread but I cant find it now.
What is this part on my steering column. I isnt hooked up to anything. Should it be and since I am getting ready to loosen the steering column to replace the rag joint is it going to interfere?
Old Mar 9, 2011 | 08:03 PM
cm2dinger's Avatar
cm2dinger
If i am not mistaken (and i could be) I'm pretty sure it is a reverse lock out and if hooked up properly you can not remove the ignition key unless the car is in reverse.
Old Mar 9, 2011 | 08:09 PM
72LS1Vette's Avatar
72LS1Vette
It is indeed the reverse lockout for a 4-speed trans. You should tie-wrap it or somehow immobilize it to prevent the lever from falling and preventing you from removing the ignition key. The better thing to do is to hook it up correctly.
Rick B.
Old Mar 9, 2011 | 08:10 PM
...Roger...'s Avatar
...Roger...
Baxsom,under the arm is a bracket and under the bracket is a hole or slot in the firewall to slide the arm through if your going to pull the column.
Old Mar 9, 2011 | 08:11 PM
HerFirstVette's Avatar
HerFirstVette
Is your car an automatic?
Old Mar 9, 2011 | 08:25 PM
HerFirstVette
The reason I ask....on my 73 automatic, that's the mechanism (and subsequent cable) that's used to make sure the transmission is in "park".
Old Mar 9, 2011 | 08:27 PM
baxsom's Avatar
baxsom
Originally Posted by HerFirstVette
The reason I ask....on my 73 automatic, that's the mechanism (and subsequent cable) that's used to make sure the transmission is in "park". I can post a picture if you like.
yes an automatic, please post what it is supposed to look like. I have seen a few pics of this thing before but I wasnt sure what it did. Getting ready to pull back the column to get the torn up coupler off.
Old Mar 9, 2011 | 08:40 PM
HerFirstVette
Picture posted
Old Mar 10, 2011 | 06:39 AM
baxsom's Avatar
baxsom
yeah that cable is long gone off of mine. does anyone have a picture of where it hooks up to on the other end (i am guessing the transmission)
Old Mar 10, 2011 | 08:04 AM
Jim Shea's Avatar
Jim Shea
There are two nuts inside the car, down by your feet, that hold that plate in your picture to the front of dash panel. Remove those nuts and the plate can be pulled back into the engine compartment and removed from the panel. Then you should see a cut out in the dash panel that will allow the steering column lever to pass through.
There are two different cables. One for automatics and another for manual shifts. They both connect to their respective transmission shift levers.
Jim
Old Mar 10, 2011 | 08:32 AM
noonie's Avatar
noonie
On a 400
Old Mar 10, 2011 | 03:38 PM
baxsom's Avatar
baxsom
yeah i so dont have that bracket either.
just one more thing i have to add to the list.
Old Mar 10, 2011 | 03:44 PM
kdf1986's Avatar
kdf1986
From reading some of the posts, should there be a similar mechanism for a 4 speed trans. I have something similar held in place with a tie wrap from the previous owner, but its a 4 speed transmission.
kdf
To steering column part
