Defroster Grill
Old Mar 11, 2011 | 02:53 AM
flaco1801's Avatar
flaco1801
Default Defroster Grill
I was cleaning the windows on my 74 and i never noticed how dirty the defroster grill is... has anybody just popped it out to clean or is it only cleaned in place? thanks, jeff
Old Mar 11, 2011 | 05:35 AM
corvetteload's Avatar
corvetteload
Well, if you mean the rear window defroster vent grille, it:
A: Doesn't pop out, 2 screws on very delicate corners hold it to the vent piece behind the panel. If you overtighten screws kiss one or both corners goodbye.
B: I would use Q-tips to clean, easier than disassembly and risking breakage.
C: If you do break, write me, I have several NOS ones
Old Mar 11, 2011 | 08:27 AM
flaco1801's Avatar
flaco1801
sorry should have said the front grill in the dash...
Old Mar 11, 2011 | 08:51 AM
dembo's Avatar
dembo
It's bolted to the upper dash pad with self threading screws from underneath, so popping it out isn't really a option. A round paintbrush with plastic cleaner ?
Nick
Old Mar 11, 2011 | 09:11 AM
flaco1801's Avatar
flaco1801
thanks Nick...had a feeling it was secured from underneath...
Old Mar 11, 2011 | 09:13 AM
Hardway's Avatar
Hardway
I had the front defrost vent out when putting in a new dash pad in my '81. It was awful! I filled up a large clear glass vase with hot water and Castrol Super Clean. After a few hours of sitting the water had turned dark brown. I took an old tooth brush and scrubbed it, letting it sit for almost an entire day. Scrubbed it some more, rinsed it, dried, and shot some fresh flat black paint on it.
Old Mar 11, 2011 | 03:10 PM
srs244's Avatar
srs244
St. Jude 15 Year Donor
St. Jude Donor '09 thru '26
if you get brave and want to replace it, i have a couple of NOS pieces i accumulated to do the restoration of my 78.
To Defroster Grill
