Trailing arms
Old Mar 12, 2011 | 08:05 AM
ICEMAN59's Avatar
ICEMAN59
Default Trailing arms
Had one H*** of a time getting drivers side trailing arm out, the bolt rust welded wound up cutting it with sawzall 4 times.
Old Mar 12, 2011 | 08:48 AM
gbvette62's Avatar
gbvette62
That's usually the only way they come out!
Old Mar 12, 2011 | 09:23 AM
GD70's Avatar
GD70
The shop that is currently rebuilding the entire suspension on my 70 had to do the same thing. Cars this old, it's rare they just unbolt & slide out.
Glenn
Old Mar 12, 2011 | 09:59 AM
jlavettez06's Avatar
jlavettez06
been there and done it.
Old Mar 12, 2011 | 10:13 AM
terry82's Avatar
terry82
cutting out the bolt is easy, wait till you try and put that little bolt back in .there are several ways to do it .i used a small needle nose pair of vise grips to hold the bolt and push it into the hole .good luck
Old Mar 12, 2011 | 09:20 PM
ICEMAN59's Avatar
ICEMAN59
Yea I had to do it by myself and it was no fun, I cussed a little
[IMG]C:\Users\Keith\AppData\Local\Microsoft\W indows\Temporary Internet Files\Content.IE5\XJM9P7FT\IMG_0041[1].JPG[/IMG]
Old Mar 13, 2011 | 10:27 AM
kdf1986's Avatar
kdf1986
I got lucky when I replaced the bolts on my 75. It was a 58,000 mile all California car. No rust on the frame. After reading about the problems getting this bolt out I was relieved that I did not have to cut it off.
But then, I did lose my reason to buy a new sawzall tool. So there is good and bad news.
kdf
To Trailing arms
