hydroboost fitting question
Old Mar 17, 2011 | 07:42 PM
baxsom's Avatar
baxsom
Default hydroboost fitting question
Hi, Finally getting a chance to work on my hydroboost unit. Right now I am working on getting the fittings attached to the unit itself. One, the 18mm one from the power steering pump screws all the way into the hydrobooster but the other one that goes into the steering cylinder doesnt not go all the way in. Is it a poorly made fitting or normal? It buries all of the threads but there is a shoulder not going in.
Here is a shot.
Old Mar 17, 2011 | 07:58 PM
'75's Avatar
'75
Do the fittings have an o-ring on the tip?
Old Mar 17, 2011 | 08:02 PM
baxsom's Avatar
baxsom
yes
Old Mar 17, 2011 | 08:18 PM
'75's Avatar
'75
My opinion is that if you feel the o-ring being compressed just before the fitting gets tight or bottoms out, it should seal.
Old Mar 17, 2011 | 08:22 PM
baxsom's Avatar
baxsom
eh, i'll give it a whirl then. worse case I have to clean a mess and i get a new one.
To hydroboost fitting question
