Manual Vette stuck in reverse..need some help.
Old Mar 22, 2011 | 03:55 PM
Scudd's Avatar
Scudd
Default Manual Vette stuck in reverse..need some help.
I can shift 1st-4th, but not into reverse. The car or sees/operates in reverse all the time when the clutch is released. any ideas?
Old Mar 22, 2011 | 04:27 PM
Cobra_4's Avatar
Cobra_4
St. Jude Donor '09
Ive done this before. Jack the car up on jack stands and get under it. You should be able to play around with the linkage and get it back into neutral.
Old Mar 22, 2011 | 04:55 PM
c31980's Avatar
c31980
agree
all u need is linkage aliment
Old Mar 23, 2011 | 01:04 AM
chvet73's Avatar
chvet73
Old Mar 23, 2011 | 08:13 AM
Scudd's Avatar
Scudd
Treied the linkage adjustment.. This is internal.
Old Mar 23, 2011 | 08:41 AM
GD70's Avatar
GD70
I hate to say it, but it sounds like the tranny needs to come out and be rebuilt.
Did you have someone sit in the car and attempt to put it in reverse while you were under neath? Might help to see what's happening. Maybe something else is binding it up. Just a thought.
Good luck.
Glenn
Old Mar 23, 2011 | 08:53 AM
Scudd's Avatar
Scudd
Good luck.
Glenn
I'm pretty sure it needs to come out.. I had this thing rebuilt about 5 years ago. It shifts great.. like a knife through butter. Just wish a had a better understanding as to how these transmisions operate in reverse. I really dont want to get taken by the transmission shop.
Old Mar 23, 2011 | 12:05 PM
Jughead's Avatar
Jughead
Senior Member since 1492
From: Just because I'm paranoid doesn't mean people aren't out to get me...
St. Jude Donor '09
I had a similar problem a couple years ago with a brand new Comp + Hurst shifter. Turned out to be the shifter.
I also had it stuck in reverse several times. Turned out to be the linkage. If I remember correctly, when in neutral the two forward levers are straight up and the reverse lever is pointed toward the rear of the car.
Loosen up the bolts & see if realigning them helps.
Old Mar 23, 2011 | 12:54 PM
Sigforty's Avatar
Sigforty
Cruise-In IX Veteran
I this happen to my 71 years back. I had to pull the trans, but once the cover was removed it was an easy fix. Some how both reverse and 4th gear were engaged at the same time. I just popped 4th out of engagement and everything has been fine since.
To Manual Vette stuck in reverse..need some help.
