Electrical issue on 79 Corvette
It happened when I was replacing my dash, my bro broke the light switch I replaced the switch with a junked one from a 78.
The wiper now makes a weird cracking noise when it is first initiated and sometime or another (I can't remember exactly what I did) I saw my lights on my tach and speedo flicker then go out.
I tested the 7.5 fuse that goes to isnt lamp but couldn't get anything from either side of the fuse. I replaced it anyway, no dice.
Headlights and wiper work
Is it fixable? My head lights do work
And I actually just remembered, it is the original light switch. We got the dash from the junked vette, and we broke the one in that dash. So we used the original light switch but a different wiper switch
Car probably won't get driven this summer.
check the tail light fuse (20amp) it sends power to the light switch, which transfers power through the light switch rheostat to the 7.5a fuse and then to the dash lights.
http://www.corvetteforum.net/c3/tune.../index12.shtml
http://www.corvetteforum.net/c3/tune.../index23.shtml
Second possible cause of no IP lights is the IP fuse in the fuse panel.
Do you have a good dash harness ground on the driver's hinge post?
