Removable Hardtop Question
Old Mar 23, 2011 | 08:32 AM
sbranscum's Avatar
sbranscum
Default Removable Hardtop Question
Ok, so I have a question and I'm just gonna ask. For a vert can you have a hardtop made that could also be t-tops so you can have the best of all three worlds?
Old Mar 23, 2011 | 09:11 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
It's your money and your hard top.
Old Mar 23, 2011 | 09:22 AM
oldsarge's Avatar
oldsarge
Enough money will get you anything, if that is what you want.
Old Mar 23, 2011 | 10:02 AM
sbranscum's Avatar
sbranscum
how much we talkin? 10,000$?
Old Mar 23, 2011 | 10:20 AM
CA-Legal-Vette's Avatar
CA-Legal-Vette
I won't ask the obvious question.
I don't think it would be all that hard. Take a hard top and cut it where the t-tops would go and attach a trim piece. I think it would stick up somewhat, which could be a problem for the seals.
Engineering and labour would significantly add to the cost. As a guess, $3 to 4 k?
Might be less expensive to buy a coupe.
Old Mar 23, 2011 | 10:31 AM
MrJlr's Avatar
MrJlr
Or trade me for my coupe....I want a vert !
Old Mar 23, 2011 | 10:32 AM
Easy Mike's Avatar
Easy Mike
You will have to let us know once you've finished your t-top hard top conversion.
Old Mar 23, 2011 | 10:56 AM
24695bob's Avatar
24695bob
Sure it would be just a matter of money....
BUT the best of 3 worlds ???? I own 3 convertibles (c2 C3 and C5) and 2 t-toped C3 couples as well as a targa topped C4...
NOTHING beats a true convertible on nice summer evening nothing beats a coupe with a solid roof at high noon in August IF the A/C works...
I HONESTLY can not remember the last time I drove on of my "coupes" without the top on... (been at least 5 or more years)...nor can I remember driving one of the convertibles with the top up (except when caught in a sudden thunderstorm) ..
Bob G.
Old Mar 23, 2011 | 11:00 AM
Mashman's Avatar
Mashman
If you are going to do it, you may as well do it all the way - so don't forget to make the rear window removable!
Old Mar 23, 2011 | 04:31 PM
68-427Rich's Avatar
68-427Rich
Default Top
[quote=sbranscum;1577136576]Ok, so I have a question and I'm just gonna ask. For a vert can you have a hardtop made that could also be t-tops so you can have the best of all three worlds?
What is this series of letters ( v e r t ) ?
Old Mar 23, 2011 | 05:35 PM
Paul L's Avatar
Paul L
Google Smooth Line, go to the C3 area, and order the optional sunroof for $250.00.
Old Mar 23, 2011 | 05:42 PM
vettebuyer6369's Avatar
vettebuyer6369
Assuming you are talking about a convertible, people don't generally have their hard tops "made."
Old Mar 23, 2011 | 07:32 PM
PRNDL's Avatar
PRNDL
I was thinking a retractable hardtop. maybe power t-tops...
Old Mar 24, 2011 | 11:44 AM
milo30's Avatar
milo30
I personally don't see the need for it, assuming you have the soft top on the car also. It could be done but would cost more than it is worth. I did see an interesting hard top in the C5 section once. The guy cut the top like a targa, making it 2 pieces. He then designed a hydraulic system that raised the rear deck lid, the front of the top lifted, the bottom raised and lowered itself into the back of the car and the front of the top then flipped over and lowered itself on top of that.
It would be much easier to cut the top and make it a targa top like the C4. Wouldn't quite be the t-top that you were asking about but close and much easier to design and seal.
Old Mar 24, 2011 | 12:03 PM
Easy Mike's Avatar
Easy Mike
Originally Posted by milo30
...It would be much easier to cut the top and make it a targa top like the C4...
The C3 was originally designed to be a targa top car. There was no T-bar. When testing the targa roof, the engineers learned that if the body flexed a little, it was difficult to get the targa top on or off.
The solution for the body flex was to add the t-bar and make the car with a pair lift off tops instead of a targa.
They did not return to the body flex problem until the C4s were being designed.
Old Mar 24, 2011 | 08:26 PM
milo30's Avatar
milo30
Ah, didn't know that. Makes sense though. Guess that's why I'm not an engineer for them. Would have sucked to cut up a top to later find that out.
To Removable Hardtop Question
