Tec support - heater fan - help
Old Mar 24, 2011 | 11:10 AM
axle83651's Avatar
axle83651
Navigator
Default Tec support - heater fan - help
I've got a 1973 Big Block Convertable and the high speed fan does not work. The two lower speeds work just fine but when switched over to high speed the fan stops. I was told there was orange wire between the drives fender and the master bake cyclinder with a fuse holder in this wire. Further that this fuse controls the high speed fan. I double and tripled checked. No fuse holder. Has anyone ran into a sinilar problem or has a cure for this.
Old Mar 24, 2011 | 11:28 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Blower fan resistor on the AC box. Sounds like the high speed coil has died.
Old Mar 24, 2011 | 12:54 PM
axle83651's Avatar
axle83651
Navigator
It worked. Thanks
To Tec support - heater fan - help
