Hood latch issues
Old Mar 24, 2011 | 12:01 PM
Vetteman75's Avatar
Vetteman75
Cruising
Default Hood latch issues
I have a 75 Vette and only the passenger side will pop, anyone have any idea how to get the hood open and how to adjust it?
Old Mar 24, 2011 | 02:33 PM
Lon Wayne's Avatar
Lon Wayne
Default Vader Vette
As long as you can get one side to pop that will leave room to reach in and grab the cable have someone push down on the driver side and pull the cable unless its broken this should open the hood adjustment they might just need greased!!
Old Mar 24, 2011 | 04:33 PM
redman76's Avatar
redman76
St. Jude Donor '09
You may also have to move hood side-to-side too. Once you get the hood to release, take some duct tape a place over female latch on hood. Then carefully lower hood until the male pin dimples the tape. This will show you if it is centered on the female. If not, then adjust the pin until it is. I used to get my hood stuck way to often; once I aligned with the tape, never had the issue again.
Old Mar 24, 2011 | 04:41 PM
Vetteman75's Avatar
Vetteman75
Cruising
Thanks everyone for the info, going to work on it tonight.....
Old Mar 26, 2011 | 09:08 AM
Vetteman75's Avatar
Vetteman75
Cruising
Thanks for all the info, however still cant get it. I pulled the cable under the hood, and everything else and still drivers side wont pop!!!
To Hood latch issues
