control arms
Old Mar 26, 2011 | 10:34 AM
SMD 1976's Avatar
SMD 1976
Default control arms
replacing all the bushings. is there a need to put lube on the inner sleeve that meets the rubber. also should angle of the arm thats bolts to frame be set before the outer part of bushing is pressed into control arm.also what type of tool do you guys use to install bushing press,c-clamp, hammer and socket. also replacing fuel tank sending unit with new is there a need for a sealant to be placed on or under bladder at tank opening also there was o-rings on the bolts that held top plate to tank can new ones be bought or reuse with sealant. don't want any leaking in this replacement job. thanks
