It never ends!!!!!
new rotors, painted calipers, new wheels and tires. Did it all then found out tire bolds were too short, Had to take everything off, put on longer bolds and redo everything. Pain
Then had to replace leaking thermostat gasket. Easy
Then took off door panels to check broken window motor. Was loose connection at motor. (GOT LUCKY) Easy
So then decided while panels were off to replace door handles . PAIN AND NOT DONE
Also decided to replace door windows. NO WAY gonna pay to have that done. (Figured it out, not gonna be that hard, ordered glass to do it myself)
Also figured while panels are off to replace carpet at bottom and put on leather that matches my two tone interior. Took them to my upholestry guy.
Also lowered the car to better fit the new tires. Had help, not hard.
IT NEVER ENDS
Then took off door panels to check broken window motor. Was loose connection at motor. Easy
IT NEVER ENDS
I saw the pics of your hood liner, so I ordered one for myself. Then after I ordered it, I said to myself why don't I clean the underside of the hood up. Well that led to sanding, which led to priming, which led to sanding again! Then buying paint to MATCH my color. Had a friend spray it on thick = several coats. Came out awesome. Now I can't put the old hardware back on. So I ordered the chrome hood latches. Then I figured since the hoods off, I might as well order the chrome covers for the headlight actuators. I saw the hood pop-up springs in chrome, so I had to buy those. What started as a 79.99 hoodliner, ended up costing me more. LOL
should have. Now with your new wheels the rest of all your hard work really stands out, She look really good.
As far as it never ends, I know just what your talking about. I am trying to finish up the rear suspension rebuild and decide
if I am going to just replace the broken 700r4 with another replacement for the summer or go ahead and dive in to my LS swap
that I have been putting off. So much work and never enough time to do it.
Riggs
You're better off here, with friends of a feather.
p.s. lookin' good.
