Fast Blinker
Old Mar 28, 2011 | 12:04 PM
Scott Spaulding's Avatar
Scott Spaulding
8th Gear
Default Fast Blinker
Does anyone know what causes a fast blinker in my 1969 vette?
Old Mar 28, 2011 | 12:27 PM
bashcraft's Avatar
bashcraft
Usually it's because a bulb has burned out.
Old Mar 28, 2011 | 02:14 PM
srs244's Avatar
srs244
St. Jude 15 Year Donor
St. Jude Donor '09 thru '26
but it can also be caused by a bulb socket that might be a bit corroded and not making good contact (making it appear that the bulb is bad by changing the current draw). of course the flasher could be bad, but that isn't usually the case.
Old Mar 29, 2011 | 06:09 PM
Scott Spaulding
8th Gear
Thanks for suggestions. I'll work through the bulbs and sockets.
Old Mar 29, 2011 | 06:36 PM
glackore's Avatar
glackore
Yep, these are all valid things to look at.
Old Mar 29, 2011 | 09:31 PM
onaqwst's Avatar
onaqwst
might be a wrong bulb in the rear also... some have 2 or 3 modes of connection i believe
Old Mar 29, 2011 | 09:34 PM
Slotehog's Avatar
Slotehog
Would these same issues cause a blinker to flash slower? My driver's side blinks significantly slower than the passenger side.
Andy
Old Mar 29, 2011 | 11:22 PM
gdm78vette's Avatar
gdm78vette
In the old days of bimetallic blinker modules a slow or no blink was usually a burnt out bulb. A fast blink could be a wrong bulb, a short of some kind or more bulbs added to the circuit than normal, like connecting trailer lights for example. This is because the blink rate was controlled by how quickly the bimetallic strip heated, distorted and disconnected the power to the bulbs. Not enough bulbs (i.e. a burnt out one), not enough current draw and the strip didn’t heat enough to distort and disconnect; too many bulbs or a short, too much current draw and the strip heated too fast.
Old Mar 29, 2011 | 11:32 PM
Clams Canino's Avatar
Clams Canino
I agree with the above. Likely brighter bulbs than stock in the Tail Lights. I think you can get a different flasher to fix this.
-W
Old Mar 30, 2011 | 07:18 AM
gdm78vette's Avatar
gdm78vette
-W
You can buy electronic replacement flashers to replace the original which would be a good idea if the flash rate problem was due to additional bulbs or brighter ones as you suggested; but would perhaps mask a burnt bulb or short issue which should be repaired.
Old Mar 31, 2011 | 10:23 AM
builder's Avatar
builder
When you check your bulbs, look at the pointed end real close. Sometimes, the tip wears to a concave shape. The bulb still works when tested, but the contact to the socket is compromised and the bulb needs to be replaced.
Old Mar 31, 2011 | 10:58 AM
billcarson's Avatar
billcarson
mine was slow,then stopped working,then i cleaned the push terminals and it was fast and then it started working sometimes.i will replace it with a louder unit so i don't ride around with the blinkers on all the time.(old man sign)
To Fast Blinker
