Zl-x
Old Apr 10, 2011 | 07:42 PM
cheviss427's Avatar
cheviss427
Default Zl-x
ZL-X, good idea or not. In a 68 vette.
Old Apr 10, 2011 | 07:58 PM
sly vette's Avatar
sly vette
What is ZL-X???
Old Apr 10, 2011 | 08:18 PM
cheviss427's Avatar
cheviss427
As far as i can tell. it's the ZL-1, but in a cast-iron block. Crate motor, over the counter sales.
Old Apr 10, 2011 | 08:46 PM
Grumpy 427's Avatar
Grumpy 427
My Motion perf book tells me that the ZL-X was a 4 bolt main 427/650 hp solid lifter motor. .588/.605 phase III cam 12.8-1 compression,open chamber heads, 850.950 0r 1050 carb
Old Apr 10, 2011 | 08:50 PM
Grumpy 427's Avatar
Grumpy 427
Cast iron heads, open chamber 2.19 int and 1.88 exh. this was called a competition engine. These heads were used on lots of versions of the 47 and 454 from Motion depending on what your needs were?
Old Apr 10, 2011 | 08:51 PM
Grumpy 427's Avatar
Grumpy 427
One more tidbit, is this motor was rated at 650 hp at 6500 and 525 tq
Old Apr 10, 2011 | 09:29 PM
TheSkunkWorks's Avatar
TheSkunkWorks
From: Graceland in a Not Correctly Restored Stingray
For what purpose is this mill going to be used?
And, what are the specs? (I've found more than one description as to what a ZL-X is.)
Old Apr 11, 2011 | 12:14 AM
Grumpy 427's Avatar
Grumpy 427
Your better off building a low compression 540. Will make over 700 hp and tq and still look lixe a 427, plus will be a pump gas motor with 10.25-1 compression. I know because my buddy has one.
Old Apr 11, 2011 | 07:14 PM
Dustup7T2's Avatar
Dustup7T2
Terrorizing Orange Cones
One of those units would be another monster in a street-legal car. Ka-ching!
Old Apr 12, 2011 | 09:57 AM
cheviss427's Avatar
cheviss427
Thanks for the info. I was thinking of stuffing this engine into my 68, but with the fuel of today i'll stick with the 468. Thanks.
To Zl-x
