[Need Help] Is anyone willing...
Old Apr 13, 2011 | 10:15 PM
Birdman's Avatar
Birdman
Default [Need Help] Is anyone willing...
to help me get my carb (and distributor/timing) tuned on my '68?
I've read the manual, tried my best, and still have problems. For instance, after finally getting the idle at a reasonable level, whenever I slightly (or at all) press the gas pedal, the RPMs jump back up to ~2K and stay there..even when driving around. And sometimes if I let it sit there, it will slowly go back down to normal..but one prod of the gas pedal and it jumps back up again.
I also want to make sure that the vacuum advance on the distributor is set right, and that my timing is optimal.
I will drive it to anyone in SC of reasonable distance to get this thing working right..and will pay (beer, money, whatever).
Old Apr 14, 2011 | 12:08 AM
6t9427's Avatar
6t9427
Does carburetor have a return spring on it?
Old Apr 14, 2011 | 12:40 AM
73, Dark Blue 454's Avatar
73, Dark Blue 454
I'll bet your fast idle is set too high. I'm assuming q-jet. On the passenger's side of the carb toward the bottom, there's a hidden adjustment screw. Turn it counter-clockwise a bit.
Pressing the gas pedal resets the choke and high idle function.
Old Apr 14, 2011 | 05:49 AM
boltnut's Avatar
boltnut
That also sounds like it could be weak springs in the distributor not pulling the weights back in. What advance kit did you put in there ? Set the timing with the advance disconnected and plugged. Rev the engine to like 2k with a light on it and see what you get. Plug advance back in and repeat.
Old Apr 14, 2011 | 06:21 AM
boltnut's Avatar
boltnut
You are running an HEI right ? What distributor ? Don't buy "mr gasket" advance springs and weight kits. JMO.
Old Apr 14, 2011 | 08:20 AM
Birdman's Avatar
Birdman
Dohhh, I should have added more info.
It's all aftermarket.. Carb is a Holly Demon with vacuum advance. Distributor is a Summit HEI. Intake is a Weiand Stealth Air Strike. Engine is 327.
But what I really wanted was to know if there was anyone local...a shop, or anything.
Old Apr 14, 2011 | 08:21 AM
Birdman's Avatar
Birdman
That's how I did it. However, when I returned to Italy, my dad timed it again. Maybe he didn't disconnect the advance..
So is it my timing or distributor advance that I need to adjust?
Old Apr 14, 2011 | 09:18 AM
boltnut's Avatar
boltnut
like i said it very likely could be a crappy advance kit in the distributor. that does not sound like the vac advance can to me. sounds like the weights are sticking open and not returning to "zero" when you let off the gas. you could try swapping a known good distributor to rule that out.
you set the transfer slots on the primaries correctly ? yes ?
Old Apr 14, 2011 | 09:24 AM
Birdman's Avatar
Birdman
Crappy advance kit in a brand new Summit HEI?
And I don't even know what transfer slots are..
Old Apr 14, 2011 | 09:30 AM
gq82's Avatar
gq82
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
You'll probably get a better response if you posted in the Southeast section of the forum.
http://forums.corvetteforum.com/sout.../?daysprune=-1
Old Apr 14, 2011 | 09:36 AM
boltnut's Avatar
boltnut
maybe not crappy but suspect and need to be checked.
transfer slot on a 4bbl must be set correctly in relation to the throttle blades or you will have all sorts of idle issues. running rich ?
brand new demon ? there are threads all over the internet about quality
control issues with those out of the box...metal shavings in passages, ect.
Old Apr 14, 2011 | 09:44 AM
boltnut's Avatar
boltnut
not trying to be a jerk but the carb and distributor are the "brains" of the N/A engine and many folks often overlook the importance of calibrating the advance and fuel curves after spending big bucks on other parts. this must be done and is hard for the hobbyist to get perfect. lots of variables and all engines respond different. you would be well ahead of the game to have a pro tune the carb and distributor for the rest of your combo. not just a backyard beer session. unless you are interested in learning to read plugs and swap out accel pumps and cams on the carb. fine tuning a car can be really fun and rewarding but usually only after a bunch of frustration is spent first ! maybe try a dyno session ?
Old Apr 14, 2011 | 10:10 AM
BBCorv70's Avatar
BBCorv70
Have you looked closely at the throttle linkage and idle stop? I have a similar problem though not as severe as you state. On mine it appears the throttle isn't returning fully, the spring pulls it 99% closed but not hard against the idle set screw. I haven't had time to work on it, many other items to deal with first, just an annoyance for now.
RE: Pro tuning.... I'm thinking the same for mine when I get to it. Needn't be dyno tuning but probably farm it out to someone who can look at the whole ignition timing/carburetor systems to get optimal performance. A Corvette shop commented about the advance weight springs in my rebuilt distributor being weaker than stock, advancing fast than they feel it should. They recommended original springs... As another poster stated, many variables to balance.
Old Apr 14, 2011 | 10:22 AM
boltnut's Avatar
boltnut
there are guys that can tune your distributor for your combo if you send it to them, but you have to know all your engine specs. there are also guys who can tune your carb real close if you ship to them.....not cheap. think like 500.00.
Old Apr 14, 2011 | 10:59 PM
Birdman's Avatar
Birdman
Funny you mention that.
Today I setup an appointment with a race shop to tune my carb and distributor. Hopefully it doesn't take long/much money?
However, after talking to a few people today all yielded the same diagnosis....vacuum leak.
Checked all my vacuum lines, and re-tightened the valve covers (loose..) and started up the car a few times...no high idle. Interesting. Wait, the other variable that was changed is that I had the air filter mounted this time, when before I had nothing on the carb.
Old Apr 15, 2011 | 02:55 AM
boltnut's Avatar
boltnut
Usually a vacuum leak is not sensitive to throttle position and the vacuum leak won't vary much due to engine speed. It is either leaking or it isn't. The valve covers and air cleaner should not cause a leak unless maybe the air cleaner is binding up the carb linkage somehow and holding the throttle open ? There are easy ways to check for vacuum leaks, like using propane or carb cleaner and spray small amounts near possible leak sites and listen for rpm changes. Also, check your plugs to see if one cylinder is running lean.
Don't let that shop touch your carb if they have not asked specific info on your engine combo.....like auto vs. Stick, rear gearing, cam duration, cubic inches, head flow, ect. Otherwise they are just stabbing in the dark.
When checking vacuum lines did any look Ill fitting, loose, or cracked ? I could see a cracked vacuum line giving an intermittent leak due to engine flex or other vibration/movement under the hood. Even a small leak in the right place will raise idle speed. Carb bolted down good ? Good gasket under it ? Many demon carbs have an idle bypass air system that is adjustable and is located under the air cleaner mounting stud....FYI...
Old Apr 15, 2011 | 11:39 PM
Birdman's Avatar
Birdman
Vacuum lines looked good.
Carb bolted down good, but dad had reused the old gasket instead of putting on the new one..could be a possibility..?
The idle bypass system is a new one to me...
One more idea...could it be the vacuum canister on the HEI distributor was in the wrong position? It was turned almost all the way in instead of all the way out (counter-clockwise) like it says in the directions..
To [Need Help] Is anyone willing...
Old Apr 16, 2011 | 06:15 AM
boltnut's Avatar
boltnut
http://www.barrygrant.com/fromBarryG...e-Addendum.pdf
No, the vac can will no cause a vacuum leak. But you could have too much advance added with it. Is it hooked to ported or manifold source ?
Old Apr 16, 2011 | 08:00 AM
Birdman's Avatar
Birdman
I wasn't suggesting that the vacuum can was causing a leak, but that it was causing the problem. It is hooked up to the timed vacuum port on the carb.
Old Apr 16, 2011 | 08:14 AM
boltnut's Avatar
boltnut
if its hooked into the carb above the throttle blades its also called ported. i havent ever heard of a vac advance can holding the rpms up after hitting the gas. not sure how it could. most of them only add 10-13 degrees of timing but yours could be way off i guess. if its hooked into ported you should really only see its effect at part throttle any way. my bet is still the weights sticking open for some reason in the distributor. do you have a gas grill ? you can hook a length of hose to the tank and sparingly "spray" possible leak areas and listen for rpm changes if you still suspect a vacuum leak.
or
http://www.aa1car.com/library/vacleak.htm
