1978 numbers question, please help.
Old Apr 14, 2011 | 04:43 PM
vettecollector's Avatar
vettecollector
Default 1978 numbers question, please help.
I am looking at a 78 Silver Anniversary.
Where do you look to find the VIN on the engine to match the car?
Did they move it? It is usually infront of the Passenger side head but
I didn't see it there? Any ideas?
Old Apr 14, 2011 | 05:01 PM
garage-ghost's Avatar
garage-ghost
That's where it's supposed to be. Maybe it got ground off during a rebuild or not the original engine.
Old Apr 14, 2011 | 05:20 PM
srs244's Avatar
srs244
St. Jude 15 Year Donor
St. Jude Donor '09 thru '26
it's on a pad in the front top passenger side of the engine to the side of the waterpump
Old Apr 14, 2011 | 06:24 PM
vettecollector
That where I thought it was, the older ones have it there.
I will have to have a better look when it gets here.
I was told it was original but with a rebuild.
Thanks guys.
Old Apr 14, 2011 | 07:59 PM
BKarol's Avatar
BKarol
It is more like a square unlike earlier years:
Old Apr 14, 2011 | 08:16 PM
LB66383's Avatar
LB66383
If it was rebuilt, they may have decked the block and ground off the numbers.
Old Apr 15, 2011 | 04:41 AM
hunt4cleanair's Avatar
hunt4cleanair
If it has a smog pump the pad is obscured by its apparatus so you have to look hard for it.
Old Apr 15, 2011 | 08:56 AM
LancePearson's Avatar
LancePearson
My 76 was also painted orange over the stamped numbers so once I knew where the l48 pad area was I could see the letters/numbers under........ then a putty knife cleaned it enough to see them.
To 1978 numbers question, please help.
