what did i do wrong lighting help
Old Apr 17, 2011 | 02:39 PM
gardtaker's Avatar
gardtaker
Default what did i do wrong lighting help
ok i removed the dash from my 76 and when i put it back together and tried to install new cd player i made a mess, i have no dash lights for one and cant get the radio to work, i spliced into the factory radio harness and used the yellow it seemed to be constant power and the grey seemed to be off the ignition. it came on for a minuet but only if i had the headlights on. the other thing i cant figure out is at the fuse panel i have the headlight buzzer with lt brow wires on top that i cant find where they connect and there seems to be a spot on the bottom for a connector to plug into but cant find any thing that matches. i replaced all bulbs while i had it out and they worked until i did the radio. any help at all would be great
Old Apr 17, 2011 | 03:03 PM
dembo's Avatar
dembo
The grey wire for the radio in the original harness is for the lighting of the radio! That would explain why it only comes on with headlights on.
I used the original yellow for key on power to the radio, constant power comes directly from the battery through a seperate fusepanel. (my radio also had a connection for lighting, so thats where the original grey went so the radio dims when I turn the headlight switch and gors to night mode when the headlights are on.
Can't help you with the second question.
Regards,
Nick
