Well, for one thing, the two part interlocking flap is too long. It should not cover the button but be careful when you trim it as it does need to go under the lower part of the bezel after it is installed.
The best thing to do is cut and X from the upper corners of the button opening to the lower corners.
BE CAREFUL NOT TO SCRATCH THE BUTTON.
Tuck the resulting flaps down into the button opening and install the bezel making sure the top of the interlocking flaps is under the bezel so that it is secured when you screw it down to the frame.
