Shifter
Old May 2, 2011 | 07:29 PM
Raffman's Avatar
Raffman
Default Shifter
I was driving the other day and noticed that when the shifter is in any gear( 4 spd M21, brand new)that it is very sloppy, 2-4 inches
any ideas
Old May 2, 2011 | 07:41 PM
buckstom's Avatar
buckstom
Default That's alot of slop
I assume you chnaged out the plastic bushings. The nuts on the side could've loosened up. I have the worst time keeping the gate on mine straight. One is either forward or backwards of the next linkage.
Old May 2, 2011 | 08:40 PM
72LS1Vette's Avatar
72LS1Vette
Use an inspection mirror and look at the left side of the assembly to see if the E-clip is bent or missing. If it is it will cost you about $0.25 to fix the problem.
Rick B.
Old May 3, 2011 | 11:09 AM
Raffman's Avatar
Raffman
Thanks guys
To Shifter
