79 tail lights mounting help needed
Old May 3, 2011 | 04:49 PM
C3Dave's Avatar
C3Dave
Default 79 tail lights mounting help needed
When I purchased my 79 the tail lights were out of the car. Is it screws or bolts that hold the lenses in? The assembly manual calls them screws, but has them going into a nut, and no size is listed. Ive found some screws that seem to work but I would like to use whats correct. TIA
Old May 3, 2011 | 04:55 PM
lukyn's Avatar
lukyn
Default screws
they thread into the mounting holes that are threaded.
Old May 3, 2011 | 06:15 PM
gbvette62's Avatar
gbvette62
75-79 tail lamps are held in by a chrome plated, oval head, Phillips, sheet metal type screw.
I don't have the size or length here at home, but I may have it at work. If I had to guess, I'd say that a #10 x 1 1/2" or 2" long oval Phillips sheet metal (or wood) screw would be pretty close.
It's not actually a nut that they thread into, but instead a nylon insert, or tube, that snaps into a metal retainer installed in the rear bumper.
All the Corvette vendors carry the correct 74-79 tail lamp screws and the insert.
Old May 3, 2011 | 06:53 PM
C3Dave's Avatar
C3Dave
Thanks gbvette62. Thats exactly what I need to know. Appreciate the info.
Old May 4, 2011 | 12:46 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Find the box these are in:
If memory serves, there are three per light.
Old May 4, 2011 | 01:30 PM
dgood's Avatar
dgood
Mike is correct, the screws go into those nylon inserts like gbvette said. There are 2 per light on a 79.
Old May 4, 2011 | 03:40 PM
C3Dave's Avatar
C3Dave
Thanks guys for the replies. The nylon inserts were already on the car. The po didnt leave me any screws and I was uncertain if it was a machine thread or screws that went into the nylon "nuts". I was able to find some stainless screws #10x2 1/2 that worked perfect.
To 79 tail lights mounting help needed
