brighter light for a 82
Old May 7, 2011 | 09:07 PM
terry82's Avatar
terry82
Default brighter light for a 82
i need a brighter light bulb for my shifter light.it lights up but it is hard to see what gear you are in .
Old May 8, 2011 | 08:20 PM
couperdecar's Avatar
couperdecar
The light for you '82 is lit from above - like my '79. Find the source.
Take a small drill bit and twist it into the light to break the feable blue lens. This will allow the bulb to directly light the console. I did this with my first '79 25 years ago , and with my second. Its still 'not blinding' - but it sure beats the hell outta what came from factory.
Old May 8, 2011 | 08:29 PM
terry82's Avatar
terry82
thanks for the reply .the light that you are refering to is for the climate controls.i need the light bulb for the shifter indicator.
Old May 9, 2011 | 10:31 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Check the candle power of the lamp in your owner's manual; look for a lamp with higher candle power.
Old May 9, 2011 | 01:39 PM
terry82's Avatar
terry82
with out looking it cant be over one candle .i checked it it comes on okay but they just are not verry bright .
To brighter light for a 82
