1968 outer splash shields
Old May 8, 2011 | 12:13 PM
Bruce42's Avatar
Bruce42
Default 1968 outer splash shields
I have a 1968 L79 Convert. not sure if early or late production. Did they come with outer splash shields . There is trace of bolts at bottom of front fender and bottom of inner fender. paragon Corvette has it in there catologue but only for 1971-72 not showing for 68-69.
thanks bruce
Old May 8, 2011 | 12:54 PM
Clams Canino's Avatar
Clams Canino
No it did not.
-W
Old May 8, 2011 | 03:41 PM
DZRick's Avatar
DZRick
If you are referring to the triangular shaped splash shields at the bottom of the fender (door side) both my '68s had them.
Old May 8, 2011 | 04:55 PM
Clams Canino
I thought he was reffering to the built in lower outer "flare" things at the bottom of the fenders. My error.
-W
Old May 8, 2011 | 10:00 PM
DZRick's Avatar
DZRick
-W
You may very well be right, I'm not really sure what bolt on outer spalsh guards are.
Old May 9, 2011 | 10:25 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Correct. My 68 has a pair. Check the AIM; they're shown.
Old May 9, 2011 | 09:21 PM
Bruce42's Avatar
Bruce42
thanks everyone, my car has the metal splash shields that attach from the frame to a metal bracket riveted to the floor. Wilcox Corvette part no. 33673.
i was referring to parts 7170 & 7168 from paragon corvette it shows only from 1970-79 front outer splash shield. I think my 68 had them . i am trying to find out if yes are they available.
thanks Bruce
Old May 9, 2011 | 09:52 PM
John 65's Avatar
John 65
Also besides these 2 outers, there are the 2 inners, and 2 directly behind yours and your passangers feet, and 2 more shields (for heat I believe)with insulation under the floor boards on each side. My early 68 didnt have those large heat shields. No holes were ever drilled in the crosssmember to mount the brackets, and never any clips in the floors for the insulation. I bought a pair, then realized the car never had them to begin with so didnt use them.
Old May 10, 2011 | 11:05 AM
Easy Mike's Avatar
Easy Mike
Post a link to the Paragon pair you reference.
Careful not to confuse splash shields with heat shields. Nomenclature sometimes gets swapped around. Review the AIM pages and use the original part numbers as references when ordering parts.
Old May 10, 2011 | 10:35 PM
jlavettez06's Avatar
jlavettez06
thanks bruce
68 had outer splash shield and they bolted to the frame the passenger sideis different then the driver side. If you need a picture let me know and I can pm you one. Finding original are not easy to find. At least that was my experience. It took me two years to find good used originals.
To 1968 outer splash shields
