My "New" 1982 Corvette Restoration Thread
if you need assistance with the CFI part of your project ... there's a lot of info over here ..... http://www.crossfire.homeip.net/
Keep us up-to-date!
Mark G
Mark G
Rick
Ok so after I got off of work at 5, work on the vette began. I had painted the new master cylinder the day before so it was ready to go (not that it mattered bc the fluid still ran over the side).
Anyways, after the first run around the block a week ago, the pedal was still traveling to the floor when you pushed lightly on it. Per the genius of Mike Dyer, he said the seal in the master was slipping to to fix that problem, we had to replace it. So twenty dollars later and a bottle of brake fluid later we have amazing brakes on the 82!!
So we drove it around the block a couple times (probably around twenty mins in total and noticed a few things. This was the first time we seriously drove it.
-We noticed that the transmisson was shifting a little hard, so we checked the fluid and it was low. With it full hot it shifts better but still when put into gear, it shifts hard. Any suggestions what might be causing this?
-The engine when cooler surged a little bit when at idle. seemed to quit when warmed up.
-The thing that i was worried the most about was how hot the whole car was running. When I was standing next to the car (in sandals) I couldnt stand to be close because of the heat. I think thats waaaay excessive. the temp guage seemed fine, but everything under the hood was waay waaay hot. Also the upper radiator hose didnt seem very firm to the touch, even though it was hot. Bad thermosdat? Tuning?
- Also do all 1982 corvettes have two fans?
Here are the pics:
Clean fluid:
New parts from texaswilkins:
Make sure the TV trans cable is adjusted/tight at WOT. I would swap in a new thermostat. Cheap fix.
A hard shift in an 82 could be caused by a bad fuel pump. The surging is also a clue. Its more like hanging. Example if you excellerate the rpms may hit 1500 or 2000 with a stall then a hard kick and a clunk. It would seem like its the transmission but this is what a bad fuel pump or leaking hose in the tank will do. The surging at idle is also a hint.
Your pump needs to supply about 9-13 psi in volume. The spring in the driver side TBI steps down the pressure to the two injectors to somewhere in between 9-13 psi depending on what its set at. So if the pump is sending 7 psi the spring does not have the ability to step up the pressure to the 9-13 you need. Mine is at 12.6 psi but I have a pump from an 1985 in there which delivers 40 psi of volume.
I suggest the you check the fuel pressure unless you have already dealt with this. I didn't go back and read all the posts.
Jim
Jim
Also, I know you replaced that fuel pump, but I have replaced those before and sometimes new ones are bad ones. AutoZone has a good set of fuel pressure gauges you can rent (free) that are very easy to use (even I did it) just to verify pressure. At least you can say you checked it and the pressure was good at idle and under load. To test under load, tape the gauge to the windshield. Just my $.02! Good luck and if you need any help with anything, I'd be more than happy to be a third hand.
I believe that Ill be checking the float. I replaced the little inch long hose in the tank, the new fuel pump actually had a new hose with it too
As you read in my last post, while we drove it around it seemed like the car was running super hot, and the upper rad hose did not feel firm when hot, so we thought to flush out all the old water from the radiator and block and then replace the thermosdat. Here are some pics:
Old t-stat
Old water. It seemed really muddy and dirty...
Painted up the t-stat housing:
Flushed the radiator, hoses, and block, and reinstalled:
Another thing that we added to the garage was a white board listing out all the things we still have to do to our vettes. I figure, the more we see them the more we will think about it and the more likely we are to do them. Check it out. (Vette titles and board courtesy of the girlfriend.)
The car still hesitates a little bit and still doesnt idle perfectly, but you would be suprised the difference that fresh gas makes in an engine. We put fresh gas in the tank on top of some old gas, and like majic a few minutes later the engine started idling fine and ran much smoother.
We also were able to hook up the scanner. The computer didnt throw any codes, BUT did give us some numbers:
RPM: 950
o2(MV): 460
OPEN LOOP
TPS (V): .46
IAC POSITION: 36
COOLANT 92 DEGREES: C
E-CELL EXPIRED: YES
MAP (kPa): 33
KNOCK: NO
CCP SOLENOID: ON
HIGH BATTERY: NO
P/N SWITCH: P-N--
TCC APPLY CKT: NO
INTEGRATR: 128
EXHAUST O2: LEAN
BLOCK LEARN: 128
A/F LEARNED: NO
O2 CROSS COUNTS: 0
PROM ID: 9531
KNOCK RETARD: 0
MAP (V): 1.24
CRANK: NO
IGNITION SWITCH: ON
TCC COMMAND: P1
According to the diagram the harness runs up the passengerside of the transmission then crosses over along the rear or the frame rail that supports the back of the tranny. It it is connected to the frame rail on the passenger side.
If you looked to the right in your picture you would see it.
