82 corvette door lock
Old May 12, 2011 | 06:08 PM
rzkas's Avatar
rzkas
Default 82 corvette door lock
hi? i got a 82 corvette with one key, this key can start the car but cannot lock the doors. those this car comes with a separate key for the doors or it the same key as the ignition..
Old May 12, 2011 | 07:48 PM
...Roger...'s Avatar
...Roger...
The ignition is different than the door key. The door key unlocks the door,spare tire and if the rear compartment door is lockable that door also.
Old May 12, 2011 | 08:47 PM
Tally Ho's Avatar
Tally Ho
From: Out Where the Buses Don't Run, Eglin AFB/ Niceville FL
2022 Corvette of the Year Finalist -- Modified
2021 C6 of the Year Winner - Modified
2020 C6 of the Year Finalist - Modified
Ignition key has a square head the door key is round. The ignition key is for ignition only. The door key works all of the other locks. You will most likely have to replace the door locks to get a key. I replaced my glove box door lock so I have three keys to control.
Old May 12, 2011 | 10:05 PM
...Roger...
Dang,forgot about the glove box.
Old May 13, 2011 | 09:34 AM
gbvette62's Avatar
gbvette62
If you have the build sheet (it may still be on the gas tank), it will give you the key codes. With the codes, just about any lock shop can make you correct keys for the car.
You can also order a copy of the original build sheets for you 82, from the Corvette Museum for about $50. Besides giving you the key codes, it will list all of the original equipment on your car, and the delivering dealer.
Old May 13, 2011 | 11:14 AM
Tally Ho's Avatar
Tally Ho
If you decide to order a build sheet from the NCM, read the disclaimer. They are missing a sequence of VIN's for 1982 and if your car falls into that sequence like mine does you will not be able to order one.
Old May 14, 2011 | 10:57 PM
rzkas's Avatar
rzkas
how about lock smith. can they make a key for me
Old May 14, 2011 | 11:09 PM
...Roger...
They sure can.
Old May 15, 2011 | 01:53 PM
moosie982's Avatar
moosie982
Default Coded lock cylinders.
It used to be that G.M. had the key code stamped into the door lock cylinders, I remember this from my days working at a Chevy dealer parts dept. Although it is a PITA to get the cylinder out of the door it is an alternative for you to consider. Dont know if the glove box lock were coded the same but you'd need a key to remove that anyway. Good luck to you,,,, Peace, moosie
Old May 16, 2011 | 02:52 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
And the theft alarm, including the t-tops.
Old Jul 5, 2011 | 01:27 AM
rzkas's Avatar
rzkas
those a 82 corvette comes with alarm. i have a 82 corvette and it has power door lock and power windows. the lock cylinder i looked at , some has long tail behind the cylinder and some don't have that tail or stem. which lock should i get for my car. with or without the long tail/stem behind the cylinder. thanks
Old Jul 5, 2011 | 06:27 AM
V8Ranger's Avatar
V8Ranger
I installed a replacement ignition / door lock set and now have 1 key for both. Wish I could change the glove box lock too...
Carl
Old Jul 8, 2011 | 01:55 AM
rzkas's Avatar
rzkas
ok that nice but do you buy the key cylinder with long tail behind the lock cylinder or you bought the other cylinder without the long stem/tail
Old Jul 8, 2011 | 06:18 AM
V8Ranger's Avatar
V8Ranger
If I understand you correctly, one of the lock assemblies is for cars with the factory security system - there is a switch that attaches to (or over) the lock that takes up some length. Actually I think the longer 'stem/tail' is for cars without the security system switch.
Carl
To 82 corvette door lock
