77 Fuel Filter Replacement
Old May 16, 2011 | 09:03 PM
slheinlein's Avatar
slheinlein
4th Gear
Default 77 Fuel Filter Replacement
I have a 77 with about 78k miles. To my knowledge, the fuel filter has never been changed. I attempted to get the fuel line off where it screws into the inlet but it is very tight. I used another wrench to hold the inlet bolt in place as instructed in my repair manual.
Anyone have any tricks to getting the fuel line off?
Old May 16, 2011 | 10:07 PM
...Roger...'s Avatar
...Roger...
You really should have a carb inlet nut wrench and a line wrench,other wise you can strip the carb threads and round the line nut.
Old May 17, 2011 | 12:51 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Add a rubber mallet to the list. You might have to give the wrench a light whack with the mallet to loosen the fitting.
Old May 17, 2011 | 01:37 PM
SanDiegoPaul's Avatar
SanDiegoPaul
From: San Diego - Deep Within The State of CONFUSION!
absolutely true
Old May 17, 2011 | 02:46 PM
C3 4ME's Avatar
C3 4ME
I have line wrenches, but I've never heard of a carb inlet nut wrench. I"ve always just used an open end wrench of hte proper size. Can someone enlighten me?
To 77 Fuel Filter Replacement
