Lower Steering Column Cover - attachment
Old May 20, 2011 | 04:20 PM
udornf4's Avatar
udornf4
Default Lower Steering Column Cover - attachment
I can't figure out what type of "speed nut" goes to the bottom (near the driver) screw attachment for the Steering Column Cover. The AIM doesn't show any detail and neither do any of the normal Corvette suppliers.
Of course, mine is missing, so I don't have anything to go by - just an empty rectangular hole:
Old May 20, 2011 | 04:30 PM
corvetteload's Avatar
corvetteload
It is a rectangular plastic insert that you screw the screw into
Old May 20, 2011 | 05:50 PM
udornf4's Avatar
udornf4
OK, thanks. I'll just engineer some plastic, I guess...
Old May 21, 2011 | 02:20 AM
VCuomo's Avatar
VCuomo
Sorry, but I believe it is a curved metal clip (with a hole) that slides up and down in the pictured slot. A replacement could easily be made using a scrap piece of sheet metal.
Old May 21, 2011 | 09:33 AM
Jim Shea's Avatar
Jim Shea
This isn't going to help much, but here is what I found.
First of all, I assume that your problem is with a 1973 Corvette. (Your profile says you own a 1973.) Both the T&T and the standard (non-adjustable) columns used the same snap-in part. (So in this case the type of column doesn't matter.)
1971-72 Corvette columns used a 7805495 Switch Retaining Grommet. (I assume it is a plastic snap-in part.)
The 1973-74 Corvette column assembly drawing was revised to change the 7805495 part to a 406306 Switch Retainer. On the assembly drawing, both parts (7805495 and the 406306) look the same so I am sure that either part will work.
I would think that the same part(s) were used through 1976 or 1977.
Sorry, I don't have any drawings of the parts.
Jim
Old May 21, 2011 | 12:12 PM
Duke94's Avatar
Duke94
Not a great picture, but this is my 71' no tilt column.
Gary
Here's a pic of the clip on a 76' T/T column I rebuilt and installed in my 71'
Old May 21, 2011 | 05:51 PM
VCuomo's Avatar
VCuomo
Gary
That is the type of clip that is in both my '72 and '73 (with or without tilt-tele).
Old May 21, 2011 | 06:02 PM
...Roger...'s Avatar
...Roger...
Note-the screw needs to be short or you can get into the wiring.
Old May 22, 2011 | 08:17 AM
Duke94's Avatar
Duke94
I can confirm that if the screw is to long, it will puncture the turnsignal harness.
Gary
Old May 22, 2011 | 05:15 PM
VCuomo's Avatar
VCuomo
Sadly, I too can confirm this...
Old May 23, 2011 | 08:20 AM
Jim Shea's Avatar
Jim Shea
It took a while searching through the AIM but I located the screw that attaches the center of the plastic instrument panel cover assembly to the retainer underneath the 1969-1976 steering column.
It is called out in UPC Section B01 to B12, sheet #23 in the 1976 AIM. It is 3909073 screw assembly. It is not the same as the two screws 3922299 (UPC 12C sheet #7) that attach the outside edges of that same panel to a metal bracket (3958714) that passes under the steering column and attaches both the bracket and the panel to the lower edge of the instrumental pad assembly.
I assume that because they are two different part numbers that they may be of different lengths. Also since the 3909073 is a screw assembly, there must be a washer as an integral part of the screw. Note that the 3922299 are called out as just "screws" and would not have washers integral to the screws.
Jim
Old May 24, 2011 | 09:05 AM
corvetteload
Sorry, been 20 yrs since I had the cover off, thought it was plastic.........
To Lower Steering Column Cover - attachment
