76 vette exhaust system
Old May 25, 2011 | 11:20 AM
markrocco's Avatar
markrocco
3rd Gear
Default 76 vette exhaust system
the 1976 exhaust system on the corvette stingray has a single pipe system branching out to two tail pipes, correct?
has anyone put another c3 dual pipe system on their 76?
is it possible?
id like to keep it oem with chevy parts.
Thanks.
Old May 25, 2011 | 12:11 PM
gbvette62's Avatar
gbvette62
The 74 Corvette exhaust system is a direct bolt on to your 76. Many owners of 75-79 Corvettes have made this swap.
Old May 25, 2011 | 12:34 PM
929nitro's Avatar
929nitro
Step up to the 2.5" system and if you are in one of those states that actually check for catalytic converters you can always get a good free flow small aftermarket one or 2 if you need it on both pipes.
Old May 25, 2011 | 12:36 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Originally Posted by markrocco
...the 1976 exhaust system on the corvette stingray has a single pipe system branching out to two tail pipes, correct?...
Yes. Correct. Front Y pipe connects to the cat con; rear Y pipe runs from the cat con to the mufflers.
Old May 25, 2011 | 06:48 PM
markrocco's Avatar
markrocco
3rd Gear
Thanks everyone for the help!
Old May 26, 2011 | 09:53 AM
24695bob's Avatar
24695bob
is it possible?
Thanks.
As noted doing this is easy and cheap ... BUT if you are altering the entire exhaust system (the car) car why are you trying to use ONLY OEM CHEVY PARTS .. Plus I know this old boy could not tell a OEM Factory installed exhaust pipe form a Pep boys exhaust pipe
My own 76 is running true duals..no cats...and just Corsa Resonators n the back...no "real"mufflers at all.. same set up as on my 79 ...my 72 was true duals from the factory but everything under the car is Flowmaster
Bob G
Old May 26, 2011 | 11:35 AM
ted13b's Avatar
ted13b
I just went thru this on my 77. Corvette America has the 74 kit, 2.5" all the way back. you can use stock or HP mufflers. Fits great too!
Old May 27, 2011 | 02:09 PM
Snoopysvet's Avatar
Snoopysvet
Corvette Central sells complete kits for 1974s, but there are different part numbers for automatic/manual transmissions.
If my car is a automatic but plan to convert to manual via Keisler or something I assume I would still order a kit for the automatic?
BTW - My car is a 78
Old May 28, 2011 | 02:34 PM
ted13b's Avatar
ted13b
Oops, I meant Corvette Central in my earlier post. I believe the differnece in the auto and stick kits are the center exhaust hanger. Order the auto now and the Kiesler kit should include a new hanger if it's necessary.
Old May 28, 2011 | 02:48 PM
SanDiegoPaul's Avatar
SanDiegoPaul
From: San Diego - Deep Within The State of CONFUSION!
is it possible?
Thanks.
You would do better to just visit a local muffler shop and just have a custom dual exhaust system installed. Muffler shop labor is much cheaper than mechanical shops charge, and you may be surprised at how little it may cost.
Old May 28, 2011 | 04:55 PM
KapsSA's Avatar
KapsSA
Active Streak: 90 Days
Had a 74 system on my 79 4 speed.
Removed it to go back to stock.
Installed it on a friends 78 automatic. One pipe(can't remember which side) came very close to the trans pan, had to dimple it slightly.
Later learned that the difference between the auto and 4 speed exhaust is in the bend of the front pipes.
Seems an auto system should fit a 4 speed Vette without a problem but no guarantees!
And there's really no factory front hanger for a 350 turbo equipted Vette. Earlier 400 turbo hangers won't work. 4 speed hanger won't work either.
To 76 vette exhaust system
