1978 - no A/C
Old May 28, 2011 | 11:33 AM
gregmuzila's Avatar
gregmuzila
Default 1978 - no A/C
not a huge deal, but no A/C in the 78 vette with L-82.
So I can try to re-charge it or replace it? Those are my only options?
Seems to be either $20 or $1000 right?
Old May 28, 2011 | 11:42 AM
qwank's Avatar
qwank
recharge it and add dye. run it for a while and then check for leaks. you might just need a hose or a condenser.
you might get lucky and it could last you all season. the Lumina I use as a daily driver has a small leak in the compressor housing. I charge it every year with the $10 bottles of freon from walmart, and it last the whole summer. its a lot cheaper then buying a $400 compressor.
Old May 28, 2011 | 02:45 PM
srs244's Avatar
srs244
St. Jude 15 Year Donor
St. Jude Donor '09 thru '26
assuming the compressor is good, to replace the dryer (which should be done if the system is dead for a while) and the hoses will be a lot less than the 1000 you mentioned. if the compressor is bad and needs replacement, you should probably go over the whole system as i'm sure more will need to be replaces (and you are at the 1000 or a bit more.)
there really aren't lots of choices. recharge and dye the system and and see what you've got. then you can make a qualified decision.
Old May 29, 2011 | 11:33 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Any automotive AC shop can test and recharge your system. R12 is still available or you can consider swappng to R-134a.
Old May 29, 2011 | 12:30 PM
69VetteFla's Avatar
69VetteFla
Thanks guys. The leaf blowers appear to be less expensive than the Metro Master Blaster. Is there any truth to the fact that they say it has a "filter" and is important. Are your blowers electric or gas? Was hoping that I could pick up an electric leaf blower but want to make sure that it has enough power to do the job. Was looking at an electric Black & Decker Leafhog (LH5000) - says it blows at 240MPH and 385 CFM of air volume.
Old May 29, 2011 | 12:31 PM
69VetteFla's Avatar
69VetteFla
Sorry guys - posted to wrong page
Old May 29, 2011 | 01:42 PM
THefley's Avatar
THefley
question, I just bought an 81 how can you tell if the AC system has been converted over to the 134a? or still taking the R12?
Old May 29, 2011 | 03:08 PM
nutsy's Avatar
nutsy
on my 72 it still has the original caps where you put the freon in. i think the converted ones have plastic caps.
To 1978 - no A/C
