center caps
Old May 31, 2011 | 10:36 PM
mwm1993's Avatar
mwm1993
Default center caps
how do you guys make sure your center caps don't fall off? I'm always worried I'm going to hit a bump and lose one they don't seem to fit all that snug
thanks in advance
mike
p.s. feeling pretty good finally getting some nice weather in new york!!
Old May 31, 2011 | 11:13 PM
myoriginal77's Avatar
myoriginal77
Thin bead of silicone.
Frank
Old Jun 1, 2011 | 07:33 AM
gbvette62's Avatar
gbvette62
Frank
Clean the wheel surface with something like rubbing alcohol first, and then use just a little bit of clear silicone. You won't need to use much.
Old Jun 1, 2011 | 05:53 PM
srs244's Avatar
srs244
St. Jude 15 Year Donor
St. Jude Donor '09 thru '26
RTV also works well
Old Jun 1, 2011 | 06:50 PM
THefley's Avatar
THefley
really? do they just push on? I just got my car and I hadn't really looked at em yet, do they just push on there? ( I had thought they would have came in from the back side when you put the wheel on.
Old Jun 2, 2011 | 03:51 PM
Texas Stinger's Avatar
Texas Stinger
Yeah they just push on
Old Jun 2, 2011 | 04:06 PM
Hardway's Avatar
Hardway
I got a set of used but free caps that had lost some of their clamping strength. I used a small dab of clear epoxy on mine and they are still on. The real test I guess will be when I need to remove them.
Old Jun 2, 2011 | 05:59 PM
Slotehog's Avatar
Slotehog
Twist them first....the first time I secured the caps with silicone and tried to remove them i thought I'd have to smash 'em with a hammer...just kept twisting until the bead broke. Then popped 'em off.
They definitely will stay put until you need to remove them though.
Andy
Old Jun 2, 2011 | 07:13 PM
BTGRN75's Avatar
BTGRN75
St. Jude Donor '11
Small dab of weather strip adhesive. 180` apart.
To center caps
